Dec 16, 2005 - 9:59 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
So ever since I put on my turbo charger I've been noticing a few strange things.
1. Before anything, I noticed a somewhat strange smell coming from my car. I believe that it's coming from the exhaust. 2. Sometimes (but not all the time, which is strange) I'll boost to like 5 psi and i get a ton of smoking coming out of my exhaust for about 3 seconds after the boosting, then it stops. Some things to consider- My oil return line could be straiter down than it is... I'd say it’s at about 20 degrees off from strait down... Also, the return line is about 1/2 inch, which I hear is small for a return line. The smell from the car could very well be oil, but it's hard to tell. Also, I've never had my car dyno tuned (yet, I'm waiting until I get on my BTM). Otherwise, the car seems to run fine. Could this be something more serious like a piston ring? Or do I just need to tune it, or straiten out my oil line? Where should I go with this? Ideas?? Please help, thanks. |
CheesyLobster Boost Problems Dec 16, 2005 - 9:59 PM
Dr_Tweak The problem could very well be your small oil retu... Dec 17, 2005 - 12:15 AM
presure2 QUOTE(CheesyLobster @ Dec 16, 2005 - 9... Dec 17, 2005 - 7:32 AM
CheesyLobster QUOTE(presure2 @ Dec 17, 2005 - 4:32... Dec 17, 2005 - 7:37 AM
presure2 are you using the restrictor listed? Dec 17, 2005 - 3:10 PM
zipstrips if ur not using a restrictor the turbo is gona be ... Dec 17, 2005 - 6:29 PM
CheesyLobster QUOTE(zipstrips @ Dec 17, 2005 - 3:2... Dec 17, 2005 - 7:50 PM
presure2 if you have an ST , your oil pressure is DEFINETLY... Dec 18, 2005 - 7:06 AM
StreetRacing10PSI "2. Sometimes (but not all the time, which is... Dec 19, 2005 - 9:26 AM![]() ![]() |
| Lo-Fi Version | Time is now: March 29th, 2026 - 2:33 PM |
