> About to purchase oil feed/return, Need some help
post Dec 18, 2005 - 7:16 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
ok, well i've read a bit about turbos and i made a list of what i will need to complete my 7afte project. i want everything to be as perfect as possible. im buying everything slowly because im not a big money baller yet so that's how i have to do things for now. anyway, im on jgstools.com and i need to buy an oil return and oil feed kit. http://www.jgstools.com/turbo/index2.html
I have a T3 turbo and 7A engine and need to know if for the feed lines i need a 36" line or 48" line. i need to know if to get it with a 1/8" standard adapter or inverted flare adapter
also, i believe manny had said it somewhere else. the 7a is usually over 50 psi and i would need a 0.063" Oil Pressure Orifice. please confirm this, anyone.
and finally, for the return/drain line, does the line have to be 18" or 24". i just wanna make sure i get the right sh!t. and would i need that 1/2" NPT Steel bung to weld it into my oil pan?
edit: one more question. im pretty sure i need a turbine oil outlet flange. please confirm.(look at my turbo pics). and i dont think i need the inlet flange. please confirm that also by looking at the pics in the thread link below. thanks.
Here are pics of my little turbo: http://www.6gc.net/forums/index.php?showtopic=31619
thanks in advance.
This post has been edited by JoKeRkId613: Dec 18, 2005 - 7:26 PM
post Dec 18, 2005 - 10:31 PM
your gonna need a bigger return line than 1/2. it should be at least 5/8 preferably 3/4"
post Dec 18, 2005 - 10:46 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
ok cool. gotcha. yea, sry about that. i had read your post from another thread about it being at least 5/8 and preferably 3/4". my bad, it's been a long day. lol. ok, i'll keep that in mind so i'm going to look for a 3/4 one. do you have any idea how long these feed and return lines should be? thanks.
Lo-Fi Version Time is now: August 31st, 2026 - 4:51 AM
