> question for people with the GT-four spoiler/blocks
post Dec 20, 2005 - 12:36 AM
i noticed that my trunk release dosnt work as well with the extra weight of the spoiler blocks. ill pop the trunk from inside the car, only to find it still locked, cause it couldnt pop up enough. i have to get out the key and turn it as i pull up the hatch with my other hand. is anyone else having the same problem? did they do anything different with the trunk release on a real gtfour?
This post has been edited by lagos: Dec 20, 2005 - 12:37 AM
post Dec 20, 2005 - 12:37 AM
Jaws4God
Joined Mar 27, '04
I don't have the blocks but i have a bigger spoiler.. mine still pops fine but its harder to lift up and it will shut harder.. Not sure how mine will compare with the blocks but it sounds like you have a lock problem...
post Dec 20, 2005 - 12:43 AM
after a while of pondering almost the same thing, I realized the center of gravity back there is different because the spoiler is pointer more towards the front of the car, rather than more weight towards the rear. The blocks themselves don't weigh much al all.
my manual release still works fine, it might be a bit harder to pull, not sure. I did notice that my remote popper doesn't work like it used to though. I believe the 205s have stronger struts in the back.
my solution, new or stronger struts I guess...I don't know
post Dec 20, 2005 - 12:50 AM
hmm dont think the strits would fix it it. it goes up and stays up fine.... the problem seems to be with the latch. its as iff whatever spring is used to pop the trunk up, cant handle the weight of the spoiler. so it pops and that locks itself right away. i get out of the car and try to pull up on the trunk and its locked
post Dec 20, 2005 - 1:14 AM
try some WD40 on it
post Dec 20, 2005 - 1:18 AM
yeah i was kind of starting to think the same thing... maybe mine is just sticking.
post Dec 20, 2005 - 9:55 AM
toyotatech
Joined Jun 14, '05
From colorado
never had any porblems with mine
post Dec 22, 2005 - 12:53 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
What, we have a hatch pop inside? Where?
**** Photobucket
post Dec 22, 2005 - 4:25 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(95CelicaST @ Dec 22, 2005 - 11:53 AM) [snapback]370067[/snapback]
next to the fuel lid release.
edit: beside the seat.
This post has been edited by WannabeGT4: Dec 22, 2005 - 4:26 PM
post Dec 22, 2005 - 4:38 PM
jgreening
Joined Jan 17, '04
From Illinois
I remember thinking something similar when I heard we had cup holders....lol.
post Dec 22, 2005 - 5:36 PM
Celicav
From Virginia
QUOTE(95CelicaST @ Dec 22, 2005 - 10:53 AM) [snapback]370067[/snapback]
Maybe this release does not exist on an ST?
post Dec 22, 2005 - 5:56 PM
gt_driFFter
Joined Nov 29, '04
QUOTE(Celicav @ Dec 22, 2005 - 5:36 PM) [snapback]370148[/snapback]
It most certainly does.
-Josh
post Dec 22, 2005 - 8:19 PM
How do you open your fuel door to put gas in ? The lever is right next to it. I have a remote trunk popper added to my alarm. There is a how-to on how to install it in the sticky at the top of the forum.
post Dec 22, 2005 - 8:46 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
yea, the st has a trunk release. i have factory 2 post spoiler with the led brake light and it weighs a bit and it wont pop enough and when i go back there, it's locked. but then again, i also have a crappy strut. so i need new struts because the trunk comes back down sometimes... not safe for ur head.
post Dec 22, 2005 - 11:01 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
mine worked fine when i had the supra spoiler on and it sits higher and weighs more than the blocks..... now my hatch is really light without it
post Dec 23, 2005 - 2:57 AM
95CelicaST
Joined Feb 5, '05
Yeah, I only have a gas door lever, nothing else. I will go and take a picture. I have no hatch pop inside.
**** Photobucket
post Dec 23, 2005 - 9:00 AM
vangSTa_celica
Joined Jul 10, '03
From Appleton,WI
^ I'll bet yours is snapped off. Mine eventually snapped off.
A Jaws4God Creation...
post Dec 23, 2005 - 11:45 PM
QUOTE(95CelicaST @ Dec 23, 2005 - 2:57 AM) [snapback]370296[/snapback]
QUOTE(vangSTa_celica @ Dec 23, 2005 - 9:00 AM) [snapback]370333[/snapback]
I have a set of the levers and cables FS if either of you want them wink.gif *perfect condition* biggrin.gif
post Dec 24, 2005 - 12:57 PM
95CelicaST
Joined Feb 5, '05
does someone want to go take a picture of theirs, so I may compare
**** Photobucket
post Dec 24, 2005 - 8:02 PM
vangSTa_celica
Joined Jul 10, '03
From Appleton,WI
I don't have the Celi anymore, but thanks for the offer Dustin.
Lo-Fi Version Time is now: August 9th, 2026 - 9:08 AM
