Dec 21, 2005 - 11:34 PM
Enthusiast ![]() ![]() Joined Dec 21, '05 From dallas Currently Offline Reputation: 3 (100%) |
I have a 96GT automatic. Im wanting to swap over to a 3sgte so that means i will have to go with a manual transmission. Im goin to go with a e153. And im going to use mr2 inner axels with V6 camry outers. So im going to order a MR2 clip. So far i did some research on it for a while using this forum. I will need mounts from an St205 because i dont want to weld. Are these mounts for the transmission or the motor? I have the part numbers on that, but if i get all ST205 mounts, does that mean i get rid of the GT mounts? Supersprynt said i will need an alternator bracket and shifter cables from the ST185 right? On the shifter cables i thought i could use GT shifter cables. Well here is all the part numbers and parts i need for this swap, is there anything else that i am missing?
12361-74340.......... Insulator.......... $47.10 12371-74440.......... Insulator.......... $88.00 12372-74500.......... Insulator.......... $109.00 12311-74160.......... Bracket, EN.......... $40.00 12321-74310.......... Bracket, EN.......... $26.00 12325-74230.......... Bracket, EN.......... $53.00 33820-2B350.......... Shift Cables.......... $341.00 I ordered these through Champion Toyota and were all a special order from Japan. Those are the list prices for those items. (713)943-7010 Direct Parts Line TRANSMISSION SWAP: -Shifter -Clutch Master cylinder -Slave cylinder -Clutch metal fluid lines -Rubber clutch line -Clutch pedal assembly -Manual brake pedal (just the pedal because John told me you dont need the whole assembly) -Manual Transmission Drivers Side Mount -Starter Relay for Manual -2 bolts for Trans- 12 by 1.25 (1 is 65mm other is 75mm) Can someone confirm me? |
sugarfree I need answers please. Dec 21, 2005 - 11:34 PM
95CelicaST If you have a GT you don't NEED to change moto... Dec 24, 2005 - 2:59 AM
Dr_Tweak He wants the E153, so yeah he does. Dec 24, 2005 - 4:21 AM
presure2 QUOTE(sugarfree @ Dec 21, 2005 - 11... Dec 24, 2005 - 7:34 AM
sugarfree Cool thanks. So if i decide to order a gt4 clip, t... Dec 24, 2005 - 3:40 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 27th, 2026 - 9:23 PM |
