Dec 23, 2005 - 5:21 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 12, '05 From Texas Currently Offline Reputation: 59 (100%) |
well, as it states, i need your opinions. . .
I went to start up my celica today (after not being driven for 1 day), and a sec after i started it, it immediately died. (i tried to start it a few more times // turning off the cd player etc.) and did not turn over. Then, since i'm kinda on a hill, i was able to start it rolling down . . . then it died . . . then, standing still, i stared it, and as soon as i did, i reved it. . . LOTS of blue smoke came out . . . (for about 5 secs...) . . . i have searched this, and blue smoke (according to pressure2) is linked with some problem w/the valve gaskets . . . and i'm thinking there is something more to this than that . . . ? anyway, please give me your ideas, and please only post if you know something key in this problem . . . Thank You, ~snap p.s. I know i have an oil leak, waiting to fix it...(it's like a $500 repair...) <------ EDIT:-------> just that much because of the labor, parts like $50 . . . and it takes a hoist // and removing a lot of stuff . . . nothing i can really do . . . This post has been edited by snapshotgt: Dec 23, 2005 - 7:55 PM -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Current: 850rwhp C6 Corvette Grandsport, Gen1 6.2L Ford Raptor |
Dec 23, 2005 - 7:12 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
What happened after that? Did the blue smoke go away?
Where is the leak from? -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Dec 23, 2005 - 7:54 PM
QUOTE(Dr_Tweak @ Dec 23, 2005 - 7:12 PM) [snapback]370520[/snapback] What happened after that? Did the blue smoke go away? Where is the leak from? Hey doc! i see (through reading threads) that you are quite an engine dude! lol! . . . anyway, the smoke died away after about 5 secs (a ploom each time i reved) . . . but after i did that, the car ran fine . . . . . . the oil leak i think is just a pan gasket . . . i can re-check about that (i have the write up about it)(but don't you have to remove a lot of stuff to get to it?) anyway, this car has been taken care of very well, but does has 208,XXX miles . . . thanks you posting! // i'll be looking for your reply! thank you, ~snap p.s. i know you charge like $500 to do a whole swap!...so $500 for a gasket!!...but this is a garage, and they like charging $80 per hour... -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Dec 23, 2005 - 7:56 PM
does the starter crank nice and strong? my guess is you have a battery/altinator related problem
Dec 23, 2005 - 7:59 PM
^ agreed. happened to me when my altinator wires burnt off so it woulkdnt charge the battery.
would run for a few then shut off. and through in valve seals for the blue smoke. so looks like u have a couple problems going on. -------------------- |
Dec 23, 2005 - 8:05 PM
hey, thanks guys . . .
yeah, it cranks strong, but i have to say, it was pretty weak when it was dieing (lol) . . . i was thinking about it being a altinator . . . but i think that was kinda new too . . . i'll def check up on that . . . (battery i know for sure is pretty darn new . . . ~ 2 months old) ~snap -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Dec 23, 2005 - 8:12 PM
Keep an eye on it, if you consistantly get blue smoke on startup then it may be your valve guide seals.
The oil pan gasket, if that's what you mean, is quite easy to replace. Well... not EASY, but not hard either. And it's $700 for a swap, just for the record -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
| Lo-Fi Version | Time is now: August 26th, 2026 - 3:58 PM |
