May 17, 2003 - 10:29 AM
![]() Enthusiast ![]() ![]() Joined May 17, '03 From Ontario, Canada Currently Offline Reputation: 1 (100%) |
In the april 2003 issue of Sport Compact Car, they did a V6 swap into an MR2 turbo with a melted piston (see page 199). They shoehorned in a 1MZ-FE 3 liter from an es300 and threw on the trd supercharger for one sick ride.
I realize hood clearance may be an issue in an ST-205, otherwise does anyone see any other problems with this swap (less the supercharger of course). Read the article if possible before responding as there is a ton of info on what is needed in the MR2 swap. |
GeEkBoY V6 engine swap May 17, 2003 - 10:29 AM
macavely i'm sure i could be done on a celica it's ... May 17, 2003 - 10:40 AM
west_minist GeEkBoY, you read it, I read it in both SCC and Tu... May 17, 2003 - 10:48 AM
Charlie97L QUOTE (west_minist @ May 17, 2003 - 8:02 AM) GeEkB... May 17, 2003 - 11:39 AM
west_minist You are right Charlie97L.
It is not for the faint... May 17, 2003 - 12:08 PM
SpyderGS I asked this question about three weeks ago. Got ... May 17, 2003 - 2:07 PM
XE_Nathaniel Screw them...
-Nate May 17, 2003 - 2:59 PM
jayi12-15psi QUOTE XE_Nathaniel Posted on May 17, 2003 - 12:13 ... May 17, 2003 - 3:54 PM
jayi12-15psi QUOTE XE_Nathaniel Posted on May 17, 2003 - 12:13 ... May 17, 2003 - 3:58 PM
Charlie97L QUOTE (SpyderGS @ May 17, 2003 - 11:21 AM) I asked... May 17, 2003 - 4:23 PM
west_minist SpyderGS, Charlie97L can help me out here.
You se... May 17, 2003 - 5:01 PM
macavely the best things are the ones thay no one else has ... May 17, 2003 - 5:19 PM
GeEkBoY Thanks for the input. It is a little way off, but... May 17, 2003 - 5:48 PM
west_minist Ok. it is nice to see something different.
if I h... May 17, 2003 - 7:57 PM
Charlie97L well, you'll have to do some custom work on th... May 17, 2003 - 8:11 PM
west_minist The wiring may not be a problem if you have a mote... May 17, 2003 - 8:14 PM
Drocay I figure anything is possible if you have enough m... May 21, 2003 - 9:16 AM
Charlie97L QUOTE (Drocay @ May 21, 2003 - 6:30 AM) I figure a... May 21, 2003 - 6:43 PM
FallenHero Is the wiering compatible? I would think you woul... May 21, 2003 - 10:29 PM
west_minist Charlie!
Have you ever seen a Nissan Pulsar... May 22, 2003 - 5:53 AM
Charlie97L QUOTE (west_minist @ May 22, 2003 - 3:07 AM) Charl... May 22, 2003 - 11:38 AM
west_minist Come come Charlie.
That type of swap is a special... May 22, 2003 - 1:03 PM
hi_rider I've been thinking about this swap for a while... May 27, 2003 - 7:05 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 2nd, 2026 - 3:19 PM |
