> 5sfte clutch, wha should i use
post Dec 27, 2005 - 4:40 AM
urbandork
Joined Jul 16, '04
From Los Angeles
just for the simplicity of it id like to stay with the stock gt set up and try to upgrade with a heavier duty clutch assembly
will this do for a 5sfte running 10ish psi
http://cgi.ebay.com/ebaymotors/F1-RACING-S...sspagenameZWDVW
F1 RACING STAGE 2 with Carbon Kevlar Steel-Back disc clutch kit is the perfect set up for Toyota Celica / MR-2 / Camry (2.2L 4cy) with upto 253 HP and 242 ft/lbs of torque. F1 RACING STAGE 2 clutch kit comes with Carbon Kevlar Steel-Back Facing disc that are resistant to slippage and burst. The discs have high capacity 6 sprung center dampers to reduce the drive train shock and impact. Increased clamp loads give the necessary capacity to handle modified engines and the pedal efforts will be slightly higher due to the higher clamp loads. All F1 RACING clutches require 500 mile break-in periods. Our picture below shows the ACTUAL item.
RETAIL PRICE: $ 325
Horsepower Rating: 253 HP at the crank / Torque Capacity: 242 ft/lbs
This complete racing clutch kit includes:
* F1 RACING Stage 2 heavy-duty Pressure Plate
* F1 RACING Stage 2 Carbon Kevlar Disc
* Release Bearing
* Alignment Tool
Part Number: F1-56130R1-12
Lo-Fi Version Time is now: August 28th, 2026 - 12:53 AM
