Jan 2, 2006 - 2:04 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
er... i'm trying to remove the piece in the trunk that is against the back of the car so i can remove the wiring harness... how do you take off those 2 small things at the top corners?
This post has been edited by elvasoshexai: Jan 2, 2006 - 5:14 PM -------------------- |
Jan 2, 2006 - 8:55 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) |
u pull straight up on the whole plastic piece
Jan 2, 2006 - 10:45 PM
QUOTE(forkee @ Jan 2, 2006 - 8:55 PM) [snapback]373854[/snapback] u pull straight up on the whole plastic piece but isn't there 2 small clip things at the top of each side to hold it in? can't figure out how to pop them out -------------------- |
Jan 3, 2006 - 12:22 AM
QUOTE(elvasoshexai @ Jan 2, 2006 - 10:45 PM) [snapback]373897[/snapback] QUOTE(forkee @ Jan 2, 2006 - 8:55 PM) [snapback]373854[/snapback] u pull straight up on the whole plastic piece but isn't there 2 small clip things at the top of each side to hold it in? can't figure out how to pop them out just pull the center, then the entire part comes out. Then there are 3 plastic screw like things at the bottom to romove, then just pull strait up. -------------------- |
| Lo-Fi Version | Time is now: September 9th, 2026 - 5:57 AM |
