Jan 3, 2006 - 3:53 PM
Enthusiast ![]() Joined Dec 28, '05 From Norway Currently Offline Reputation: 0 (0%) |
Hi all,
ok here is the deal. I imported me a 1995 Celica Gt just about 6 months ago. What a great car! -------------------- ![]() |
Jan 3, 2006 - 5:38 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 3, '04 From Yakima, WA Currently Offline Reputation: 1 (100%) |
warped rotors possible ?
-------------------- the 1/4 doesnt have patience for a ST.... so we make them ST-T's so atleast we'll sound good going slow.
Jan 3, 2006 - 6:16 PM
Enthusiast ![]() ![]() ![]() Joined Aug 14, '05 From Corpus Christi Tx Currently Offline Reputation: 5 (100%) |
warped rotors it is....
Jan 3, 2006 - 6:27 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
get them cut or replace them
-------------------- ![]() I will return one day. |
Jan 3, 2006 - 6:29 PM
Enthusiast ![]() Joined Dec 31, '04 From white hall, Maryland Currently Offline Reputation: 0 (0%) |
do u use ur brakes really hard?? u know like go 80 mph then try to stop in a hurry?. first dont buy cheap rotors. 2nd slow down, and 3rd ur rotors are gettin warped some how but im sure u already know that. ill see what else i can find
-------------------- [font=Comic Sans Ms][size=3]
SI VIS PACEM PARA BELLUM (if you wish for peace, prepare for war!) |
Jan 3, 2006 - 6:32 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 25, '03 From Miami, FL Currently Offline Reputation: 9 (100%) |
just remove your brake pads and calipers and it'll stop shaking.
Jan 4, 2006 - 12:04 PM
Hahaha, I should really just drive without them..! I can remember I had a speed run against a Pueguot once and the road was really harsh, braked a lot and hard. Well, I replaced the rotors with original Toyota ones. Any suggestions for good rotors that is a direct bolt on?
Jan 4, 2006 - 12:11 PM
you might want to check into upgraded ceramic pads such as EBC or sumthing similar
and drilled rotors such as i-rotors |
Jan 4, 2006 - 12:31 PM
nopi has brembo rotors for 21 each, 12-15 to ship each
also when you get your rotors trimed, cut or replaced, sand the pads down a little, get the glaze off them -------------------- ![]() |
Jan 4, 2006 - 3:00 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) |
Must be cheap rotors if they are warped already.... sounds like that is the problem though
Jan 4, 2006 - 3:34 PM
QUOTE Must be cheap rotors if they are warped already.... sounds like that is the problem though Original Toyota ones -------------------- ![]() |
Jan 5, 2006 - 11:41 AM
Called Toyota today and wohoo! They are giving me new rotors for free since it is covered by some sort of warranty
This post has been edited by eliaz: Jan 5, 2006 - 11:42 AM -------------------- ![]() |
Jan 5, 2006 - 12:10 PM
you always want to break them in take it easy for a few hundred miles then try to brake earlier and lighter from now on
Jan 5, 2006 - 2:03 PM
stop putting glazed pads on fresh rotors, see if you can get new pads free too!
| Lo-Fi Version | Time is now: August 26th, 2026 - 6:37 AM |
