> Help Me Accident whit Water, Wet part of the electric system
post Jan 4, 2006 - 11:53 AM
Celika
Joined Apr 25, '04
From Bolivia, Oruro
I had an accident my city full with water rain and my car you full with water and you wets an electric part under the driver's seat. Which the function of this part is?. When opening this part you do leave a green foam (does he/she look in the pictures) what I should make ? frown.gif
It's a 94 JDM Celica 3SGE Engine
SPANISH:
Tuve un accidente mi ciudad lleno de agua lluvia y mi auto se lleno de agua y se mojo una parte electrica debajo del asiento del conductor. Cual es la funcion de esta parte ?. Al abrir esta parte se ve una espuma verde (mira en las fotos) que es lo que debo hacer?
Es un Celica 94 JDM motor 3SGE
Agradeceria si la respuesta en es EspaƱol
Under the driver's seat Part
Opened Part
Here forms foam but it already cleans it
Replies (1 - 6)
post Jan 4, 2006 - 4:32 PM
Cutrara
Joined May 6, '05
From PA
If it is under the driver's seat, It might be the secondary stereo amplifier. Do you have an 8 speaker stereo?
post Jan 4, 2006 - 4:38 PM
creis
Joined Jan 10, '04
From Shoreline, WA
the amps are under the climate control in the dash not under the seat though, only thing that would be under the seat is the factory alarm and that is not it.
I wana say it looks like it has domething to do with the starter, the connector on it looks like the connector behind the key, for the ignition.
Does the car run fine, like normal, or does it not work.
best way to figure it out if no one knows for shure is to figure out what does not work in the car.
This post has been edited by creis: Jan 4, 2006 - 4:39 PM
post Jan 4, 2006 - 5:00 PM
Cutrara
Joined May 6, '05
From PA
I thought if you had the 6 speaker, you had one amp under the climate control. If you had the 8 speaker, you had one under the seat, too?
post Jan 4, 2006 - 7:59 PM
Celika
Joined Apr 25, '04
From Bolivia, Oruro
I've 4 speakers Stereo, my car was working with this part wet, i take it out, i don't try to start again, until the car is complete dry. To prevent a Problem
post Jan 4, 2006 - 10:46 PM
creis
Joined Jan 10, '04
From Shoreline, WA
^ good idea, not starting the car till it dryes out. Wile I cant be 100% sure I really dont think its an amp, maily because if it was an amp it would be in a metel case for heat distrobution, and the internals dont look like an amp, but then again it does not look like anything I have ever seen.
post Jan 4, 2006 - 11:59 PM
macavely
Joined Nov 4, '02
that looks like a shock sensor ... do you have an alram system in your car ? .... and if is is anything that has to do with starting your car it wouldn be under the driver seat.. to easy to get damaged under there ..
Lo-Fi Version Time is now: August 27th, 2026 - 4:08 AM
