Jan 10, 2006 - 11:02 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
Ideal Offset in Relation to Wheel Width (standard ride height):
Width - Offset 7.0"-----30mm with 15mm spacer (effectively 15mm) * 7.5"-----31mm with 10mm spacer (effectively 21mm) * 8.0"-----33mm with 05mm spacer (effectively 28mm) * 8.5"-----35mm 9.0"-----42mm (probably too wide no matter what offset) This will make the rim almost flush with the side of the body. These offsets and offset/spacer combos will prevent the "sucked in look" that the factory wheels have. Ideal Offset in Relation to Wheel Width (lower ride height): Width - Offset 7.0"-----36mm with 10mm spacer (effectively 26mm) * 7.5"-----33mm 8.0"-----40mm 8.5"-----46mm * 9.0"-----53mm (probably too wide no matter what offset) The rim will sit just behind the fender. In order for the rims to tuck into the fender well on lowered cars the the rim must sit back into the wheel well by 11mm compared to the standard ride height offset recommendations. * Clearance issues prevent the use of most rims with offsets lower than 30mm. The spacer will actually lower the offset and at the same time move the rim away from the offending components. * 8.5" rims may or may not fit on lowered cars. Offsets shown are positive. Offset is measured from the wheels center line to the mounting surface.
This post has been edited by WannabeGT4: Jan 11, 2006 - 5:18 PM -------------------- ![]() Project ST204.5 99.88946% complete... |
WannabeGT4 Wheel Offset Guide Jan 10, 2006 - 11:02 PM
tovejas so basically the smaller the offset the closer the... Jan 10, 2006 - 11:07 PM
WannabeGT4 QUOTE(tovejas @ Jan 10, 2006 - 10:07... Jan 10, 2006 - 11:13 PM
jgreening This might be for a flush look and it will probabl... Jan 10, 2006 - 11:17 PM
WannabeGT4 Thanks for the heads up jay. The math I used was b... Jan 10, 2006 - 11:29 PM
jgreening QUOTE(WannabeGT4 @ Jan 10, 2006 - 10... Jan 10, 2006 - 11:35 PM
WannabeGT4 QUOTE(jgreening @ Jan 10, 2006 - 10... Jan 11, 2006 - 10:31 AM
jgreening QUOTE(WannabeGT4 @ Jan 11, 2006 - 9... Jan 11, 2006 - 4:08 PM
WannabeGT4 I added the offsets per wheel width for lowered ca... Jan 11, 2006 - 5:09 PM
JoKeRkId613 This is good stuff. So from my understanding, addi... Jan 11, 2006 - 8:24 PM
WannabeGT4 If you plan on lowering it you don't need to d... Jan 11, 2006 - 9:33 PM
JoKeRkId613 QUOTE(WannabeGT4 @ Jan 11, 2006 - 7... Jan 12, 2006 - 1:25 PM
jgreening Justin are you sure that a 40 offset on a 8" ... Jan 11, 2006 - 9:38 PM
WannabeGT4 QUOTE(jgreening @ Jan 11, 2006 - 8:3... Jan 11, 2006 - 9:49 PM
tovejas whats the offset on the stock 15" wheels? Jan 12, 2006 - 12:11 PM
WannabeGT4 Most say it's about 37 or 38 for the 15"x... Jan 12, 2006 - 12:54 PM
WannabeGT4 You won't be able to tell a difference with or... Jan 12, 2006 - 2:48 PM
CelicaZR Sorry to bring up an old thread.
I'm currently... Mar 29, 2006 - 5:41 AM
WannabeGT4 It'll fit but it will look just as sucked in a... Mar 29, 2006 - 6:59 AM
CelicaZR Cool
Thanks Wannabe.
I guess I'll look for a... Mar 29, 2006 - 7:10 AM
bufferdan My g/f is about to be putting some 17x8's +35 ... Mar 29, 2006 - 10:23 AM
Valo666 Can some one sticky this??..its usefull. Mar 29, 2006 - 9:08 PM
97lestyousay QUOTE(Valo666 @ Mar 29, 2006 - 6:08 ... Mar 29, 2006 - 10:07 PM
Valo666 right..im an idiot Mar 29, 2006 - 10:19 PM
Tech9ine do any of you know what kind of spacer i will need... Mar 29, 2006 - 10:34 PM
malpaso QUOTE(Tech9ine @ Mar 30, 2006 - 5:34... Mar 30, 2006 - 1:03 AM
bufferdan You could actually use 15mm spacers on GTS rims to... Mar 30, 2006 - 9:38 AM
bufferdan 17x8 +35 Offset with 215/45/17 ...Fronts are prett... Apr 3, 2006 - 10:13 AM
tovejas anyone know wat the offset is for our stock rims (... Apr 9, 2006 - 10:12 PM
WannabeGT4 QUOTE(tovejas @ Apr 9, 2006 - 10:12 ... Apr 9, 2006 - 11:25 PM
CelicaZR Hey guy found another set of wheels
I need some ... Apr 20, 2006 - 6:54 AM
malpaso QUOTE(CelicaZR @ Apr 20, 2006 - 1:54... Apr 20, 2006 - 7:20 AM
WannabeGT4 17 - 29mm spacer depending on if you're lowere... Apr 20, 2006 - 7:22 AM
CelicaZR you didnt answer question 1 guys
But thanks for ... Apr 20, 2006 - 7:30 AM
malpaso QUOTE(CelicaZR @ Apr 20, 2006 - 2:30... Apr 20, 2006 - 7:54 AM
Manta5x how would these look on my car?
http://www.discoun... May 15, 2006 - 8:33 PM
malpaso QUOTE(Manta5x @ May 16, 2006 - 3:33 ... May 16, 2006 - 1:35 AM
Manta5x excellent diagram , thank you very much Malpaso. May 16, 2006 - 9:20 AM
CelicaZR Would 18 x 8 +44 offset fit? Jul 6, 2006 - 7:26 AM
WannabeGT4 Yep. Jul 6, 2006 - 10:00 AM
jdg371 I want some 16x8s for my car.. would most likely b... Jul 6, 2006 - 6:34 PM
WannabeGT4 40mm should fit just fine. Jul 6, 2006 - 6:35 PM
devilsden97 i have 17x8 with a 32 mm offset and they rock
edi... Jul 6, 2006 - 6:39 PM
WannabeGT4 QUOTE(devilsden97 @ Jul 6, 2006 - 6... Jul 6, 2006 - 6:46 PM
devilsden97 im on sportline springs....and on 225/45/17 tires ... Jul 6, 2006 - 6:50 PM
jgreening QUOTE(devilsden97 @ Jul 6, 2006 - 6... Jul 6, 2006 - 10:14 PM
jdg371 So 8in is too wide for 225/50s? what size tires wo... Jul 7, 2006 - 2:08 PM
malpaso QUOTE(jdg371 @ Jul 7, 2006 - 9:08 PM... Jul 8, 2006 - 3:00 AM
Predator ok, so i'm totally retarded when it comes to r... Oct 24, 2006 - 4:20 PM
WannabeGT4 What is the offset of your current wheels? Oct 24, 2006 - 5:47 PM
Predator i think it's 35 Oct 25, 2006 - 11:13 AM
Griff I am going to upgrade to these Konig's
http://... Nov 10, 2006 - 10:30 PM
Griff anyone? Nov 14, 2006 - 7:13 AM
bufferdan 18x8 +40 will be fine... Nov 14, 2006 - 9:04 AM
Griff is the '...' , mean anything like...probba... Nov 14, 2006 - 6:31 PM
Jdog1385 ok so im installing 15mm spacers and id like a 17x... Nov 27, 2006 - 10:43 AM
WannabeGT4 40mm. No spacer. Nov 27, 2006 - 12:09 PM
Jdog1385 QUOTE(WannabeGT4 @ Nov 27, 2006 - 12... Nov 27, 2006 - 1:28 PM
Alex-UKSC Just had a blow out so need some help.
I took the... Apr 18, 2007 - 1:52 PM
black13 some guy is selling his 7.5", + 45mm, 225/45/... Apr 27, 2007 - 4:11 AM
WannabeGT4 That'd be about half an inch further sucked in... Apr 27, 2007 - 7:47 AM
black13 it's for rims + tires of yokohama advan. for ... Apr 27, 2007 - 1:59 PM
95CelicaST QUOTEsome guy is selling his 7.5", + 45mm, 22... Apr 27, 2007 - 2:04 PM
GTSOwner 235/40-17 Falken Azenis RT-615 on 17x8, et +35 whe... Apr 29, 2007 - 11:13 PM
94gts 17x8 +50 offset ... would there be any issues runn... Jul 10, 2007 - 8:42 AM
topshed QUOTE(GTSOwner @ Apr 30, 2007 - 5:13... Jul 10, 2007 - 11:28 AM
CelicaGTS94 I am running 17x7 rims with a 205/40/17 tire with ... Jul 10, 2007 - 12:22 PM
bufferdan QUOTE(GTSOwner @ Apr 30, 2007 - 4:13... Jul 10, 2007 - 12:56 PM
CelicaGTS94 QUOTE(bufferdan @ Jul 10, 2007 - 5:5... Jul 16, 2007 - 11:56 AM
CelicaGTS94 I forgot to mention I am lower 1.5" on Tein s... Jul 11, 2007 - 7:42 AM
LadyHavoc i thought this was a sticky? no? Jul 13, 2007 - 11:35 PM
bufferdan 17x8 +35 is a good setup for the 6gc. Tire size i... Jul 16, 2007 - 12:49 PM
6strngs I am considering some 17x8 with a 46 offset and wa... Nov 15, 2007 - 2:18 AM
oldmonk I just bought a 1996 Celica ST. Can someone tell m... Nov 21, 2007 - 4:19 PM
thespacepanda Ok, to bring a very old thread back, I'm looki... Dec 13, 2007 - 9:18 PM
6strngs QUOTE(thespacepanda @ Dec 13, 2007 - 6... Dec 14, 2007 - 3:40 AM
Celicam8 If you put an offset, arn't you taking the ris... Dec 15, 2007 - 12:15 AM
njccmd2002 edit : duplicated Jan 12, 2008 - 3:19 PM
Penkka Could someone please tell me this thing.
I´ve bee... Jan 17, 2008 - 5:26 PM
thespacepanda QUOTE(Penkka @ Jan 17, 2008 - 10:26 ... Jan 17, 2008 - 6:06 PM
Penkka QUOTE(thespacepanda @ Jan 17, 2008 - 6... Jan 17, 2008 - 6:33 PM
thespacepanda That's pretty close to flush. Maybe a few more... Jan 17, 2008 - 6:45 PM
Penkka QUOTE(thespacepanda @ Jan 17, 2008 - 6... Jan 17, 2008 - 6:47 PM
thespacepanda QUOTE(Penkka @ Jan 17, 2008 - 11:47 ... Jan 17, 2008 - 6:54 PM
Penkka QUOTE(thespacepanda @ Jan 17, 2008 - 6... Jan 17, 2008 - 7:01 PM
thespacepanda Nobody got it? Anybody? Alright, I'll go back ... Jan 17, 2008 - 8:20 PM
6strngs QUOTE(thespacepanda @ Jan 17, 2008 - 5... Jan 17, 2008 - 9:34 PM
Daftboy What size spacers should i get to get my wheels fl... Jan 18, 2008 - 3:52 PM
WannabeGT4 QUOTE(Daftboy @ Jan 18, 2008 - 2:52 ... Jan 18, 2008 - 4:20 PM
Penkka QUOTE(Daftboy @ Jan 18, 2008 - 3:52 ... Jan 19, 2008 - 6:27 AM
6strngs QUOTE(Penkka @ Jan 19, 2008 - 3:27 A... Jan 19, 2008 - 1:43 PM
Daftboy 15mm will not sit it flush i think.... i was think... Jan 18, 2008 - 5:28 PM
6strngs QUOTE(Daftboy @ Jan 18, 2008 - 2:28 ... Jan 18, 2008 - 5:41 PM
WannabeGT4 I said 15mm because you're lowered. If you wer... Jan 18, 2008 - 5:46 PM
Daftboy Well if I went to 25mm I would get new bolts ...sa... Jan 18, 2008 - 8:14 PM
6strngs 25mm is almost one full inch, if when you put your... Jan 18, 2008 - 9:37 PM
Daftboy As he said.....plus the only way too get 8JJ for ... Jan 19, 2008 - 2:15 PM
Culpable04 and if you live where you get snow and your celi i... Jan 19, 2008 - 3:07 PM
Daftboy with 15mm spacers do we need longer bolts? or shou... Jan 20, 2008 - 3:00 AM
Culpable04 you'll need longer studs Jan 20, 2008 - 3:05 AM![]() ![]() |
| Lo-Fi Version | Time is now: May 17th, 2026 - 10:54 AM |
