> Wheel Offset Guide, Unsure about proper offset? Look here first.
post Jan 10, 2006 - 11:02 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Ideal Offset in Relation to Wheel Width (standard ride height):
Width - Offset
7.0"-----30mm with 15mm spacer (effectively 15mm) *
7.5"-----31mm with 10mm spacer (effectively 21mm) *
8.0"-----33mm with 05mm spacer (effectively 28mm) *
8.5"-----35mm
9.0"-----42mm (probably too wide no matter what offset)
This will make the rim almost flush with the side of the body. These offsets and offset/spacer combos will prevent the "sucked in look" that the factory wheels have.
Ideal Offset in Relation to Wheel Width (lower ride height):
Width - Offset
7.0"-----36mm with 10mm spacer (effectively 26mm) *
7.5"-----33mm
8.0"-----40mm
8.5"-----46mm *
9.0"-----53mm (probably too wide no matter what offset)
The rim will sit just behind the fender. In order for the rims to tuck into the fender well on lowered cars the the rim must sit back into the wheel well by 11mm compared to the standard ride height offset recommendations.
* Clearance issues prevent the use of most rims with offsets lower than 30mm. The spacer will actually lower the offset and at the same time move the rim away from the offending components.
* 8.5" rims may or may not fit on lowered cars.
Offsets shown are positive.
Offset is measured from the wheels center line to the mounting surface.
This post has been edited by WannabeGT4: Jan 11, 2006 - 5:18 PM
- WannabeGT4   Wheel Offset Guide   Jan 10, 2006 - 11:02 PM
- - tovejas   so basically the smaller the offset the closer the...   Jan 10, 2006 - 11:07 PM
|- - WannabeGT4   QUOTE(tovejas @ Jan 10, 2006 - 10:07...   Jan 10, 2006 - 11:13 PM
- - jgreening   This might be for a flush look and it will probabl...   Jan 10, 2006 - 11:17 PM
- - WannabeGT4   Thanks for the heads up jay. The math I used was b...   Jan 10, 2006 - 11:29 PM
|- - jgreening   QUOTE(WannabeGT4 @ Jan 10, 2006 - 10...   Jan 10, 2006 - 11:35 PM
|- - WannabeGT4   QUOTE(jgreening @ Jan 10, 2006 - 10...   Jan 11, 2006 - 10:31 AM
|- - jgreening   QUOTE(WannabeGT4 @ Jan 11, 2006 - 9...   Jan 11, 2006 - 4:08 PM
- - WannabeGT4   I added the offsets per wheel width for lowered ca...   Jan 11, 2006 - 5:09 PM
- - JoKeRkId613   This is good stuff. So from my understanding, addi...   Jan 11, 2006 - 8:24 PM
- - WannabeGT4   If you plan on lowering it you don't need to d...   Jan 11, 2006 - 9:33 PM
|- - JoKeRkId613   QUOTE(WannabeGT4 @ Jan 11, 2006 - 7...   Jan 12, 2006 - 1:25 PM
- - jgreening   Justin are you sure that a 40 offset on a 8" ...   Jan 11, 2006 - 9:38 PM
|- - WannabeGT4   QUOTE(jgreening @ Jan 11, 2006 - 8:3...   Jan 11, 2006 - 9:49 PM
- - tovejas   whats the offset on the stock 15" wheels?   Jan 12, 2006 - 12:11 PM
- - WannabeGT4   Most say it's about 37 or 38 for the 15"x...   Jan 12, 2006 - 12:54 PM
- - WannabeGT4   You won't be able to tell a difference with or...   Jan 12, 2006 - 2:48 PM
- - CelicaZR   Sorry to bring up an old thread. I'm currently...   Mar 29, 2006 - 5:41 AM
- - WannabeGT4   It'll fit but it will look just as sucked in a...   Mar 29, 2006 - 6:59 AM
- - CelicaZR   Cool Thanks Wannabe. I guess I'll look for a...   Mar 29, 2006 - 7:10 AM
- - bufferdan   My g/f is about to be putting some 17x8's +35 ...   Mar 29, 2006 - 10:23 AM
- - Valo666   Can some one sticky this??..its usefull.   Mar 29, 2006 - 9:08 PM
|- - 97lestyousay   QUOTE(Valo666 @ Mar 29, 2006 - 6:08 ...   Mar 29, 2006 - 10:07 PM
- - Valo666   right..im an idiot   Mar 29, 2006 - 10:19 PM
- - Tech9ine   do any of you know what kind of spacer i will need...   Mar 29, 2006 - 10:34 PM
|- - malpaso   QUOTE(Tech9ine @ Mar 30, 2006 - 5:34...   Mar 30, 2006 - 1:03 AM
- - bufferdan   You could actually use 15mm spacers on GTS rims to...   Mar 30, 2006 - 9:38 AM
- - bufferdan   17x8 +35 Offset with 215/45/17 ...Fronts are prett...   Apr 3, 2006 - 10:13 AM
- - tovejas   anyone know wat the offset is for our stock rims (...   Apr 9, 2006 - 10:12 PM
|- - WannabeGT4   QUOTE(tovejas @ Apr 9, 2006 - 10:12 ...   Apr 9, 2006 - 11:25 PM
- - CelicaZR   Hey guy found another set of wheels I need some ...   Apr 20, 2006 - 6:54 AM
|- - malpaso   QUOTE(CelicaZR @ Apr 20, 2006 - 1:54...   Apr 20, 2006 - 7:20 AM
- - WannabeGT4   17 - 29mm spacer depending on if you're lowere...   Apr 20, 2006 - 7:22 AM
- - CelicaZR   you didnt answer question 1 guys But thanks for ...   Apr 20, 2006 - 7:30 AM
|- - malpaso   QUOTE(CelicaZR @ Apr 20, 2006 - 2:30...   Apr 20, 2006 - 7:54 AM
- - Manta5x   how would these look on my car? http://www.discoun...   May 15, 2006 - 8:33 PM
|- - malpaso   QUOTE(Manta5x @ May 16, 2006 - 3:33 ...   May 16, 2006 - 1:35 AM
|- - Manta5x   excellent diagram , thank you very much Malpaso.   May 16, 2006 - 9:20 AM
- - CelicaZR   Would 18 x 8 +44 offset fit?   Jul 6, 2006 - 7:26 AM
- - WannabeGT4   Yep.   Jul 6, 2006 - 10:00 AM
- - jdg371   I want some 16x8s for my car.. would most likely b...   Jul 6, 2006 - 6:34 PM
- - WannabeGT4   40mm should fit just fine.   Jul 6, 2006 - 6:35 PM
- - devilsden97   i have 17x8 with a 32 mm offset and they rock edi...   Jul 6, 2006 - 6:39 PM
|- - WannabeGT4   QUOTE(devilsden97 @ Jul 6, 2006 - 6...   Jul 6, 2006 - 6:46 PM
- - devilsden97   im on sportline springs....and on 225/45/17 tires ...   Jul 6, 2006 - 6:50 PM
|- - jgreening   QUOTE(devilsden97 @ Jul 6, 2006 - 6...   Jul 6, 2006 - 10:14 PM
- - jdg371   So 8in is too wide for 225/50s? what size tires wo...   Jul 7, 2006 - 2:08 PM
|- - malpaso   QUOTE(jdg371 @ Jul 7, 2006 - 9:08 PM...   Jul 8, 2006 - 3:00 AM
- - Predator   ok, so i'm totally retarded when it comes to r...   Oct 24, 2006 - 4:20 PM
- - WannabeGT4   What is the offset of your current wheels?   Oct 24, 2006 - 5:47 PM
- - Predator   i think it's 35   Oct 25, 2006 - 11:13 AM
- - Griff   I am going to upgrade to these Konig's http://...   Nov 10, 2006 - 10:30 PM
- - Griff   anyone?   Nov 14, 2006 - 7:13 AM
- - bufferdan   18x8 +40 will be fine...   Nov 14, 2006 - 9:04 AM
- - Griff   is the '...' , mean anything like...probba...   Nov 14, 2006 - 6:31 PM
- - Jdog1385   ok so im installing 15mm spacers and id like a 17x...   Nov 27, 2006 - 10:43 AM
- - WannabeGT4   40mm. No spacer.   Nov 27, 2006 - 12:09 PM
|- - Jdog1385   QUOTE(WannabeGT4 @ Nov 27, 2006 - 12...   Nov 27, 2006 - 1:28 PM
- - Alex-UKSC   Just had a blow out so need some help. I took the...   Apr 18, 2007 - 1:52 PM
- - black13   some guy is selling his 7.5", + 45mm, 225/45/...   Apr 27, 2007 - 4:11 AM
- - WannabeGT4   That'd be about half an inch further sucked in...   Apr 27, 2007 - 7:47 AM
- - black13   it's for rims + tires of yokohama advan. for ...   Apr 27, 2007 - 1:59 PM
- - 95CelicaST   QUOTEsome guy is selling his 7.5", + 45mm, 22...   Apr 27, 2007 - 2:04 PM
- - GTSOwner   235/40-17 Falken Azenis RT-615 on 17x8, et +35 whe...   Apr 29, 2007 - 11:13 PM
- - 94gts   17x8 +50 offset ... would there be any issues runn...   Jul 10, 2007 - 8:42 AM
- - topshed   QUOTE(GTSOwner @ Apr 30, 2007 - 5:13...   Jul 10, 2007 - 11:28 AM
- - CelicaGTS94   I am running 17x7 rims with a 205/40/17 tire with ...   Jul 10, 2007 - 12:22 PM
- - bufferdan   QUOTE(GTSOwner @ Apr 30, 2007 - 4:13...   Jul 10, 2007 - 12:56 PM
|- - CelicaGTS94   QUOTE(bufferdan @ Jul 10, 2007 - 5:5...   Jul 16, 2007 - 11:56 AM
- - CelicaGTS94   I forgot to mention I am lower 1.5" on Tein s...   Jul 11, 2007 - 7:42 AM
- - LadyHavoc   i thought this was a sticky? no?   Jul 13, 2007 - 11:35 PM
- - bufferdan   17x8 +35 is a good setup for the 6gc. Tire size i...   Jul 16, 2007 - 12:49 PM
- - 6strngs   I am considering some 17x8 with a 46 offset and wa...   Nov 15, 2007 - 2:18 AM
- - oldmonk   I just bought a 1996 Celica ST. Can someone tell m...   Nov 21, 2007 - 4:19 PM
- - thespacepanda   Ok, to bring a very old thread back, I'm looki...   Dec 13, 2007 - 9:18 PM
|- - 6strngs   QUOTE(thespacepanda @ Dec 13, 2007 - 6...   Dec 14, 2007 - 3:40 AM
- - Celicam8   If you put an offset, arn't you taking the ris...   Dec 15, 2007 - 12:15 AM
- - njccmd2002   edit : duplicated   Jan 12, 2008 - 3:19 PM
- - Penkka   Could someone please tell me this thing. I´ve bee...   Jan 17, 2008 - 5:26 PM
|- - thespacepanda   QUOTE(Penkka @ Jan 17, 2008 - 10:26 ...   Jan 17, 2008 - 6:06 PM
|- - Penkka   QUOTE(thespacepanda @ Jan 17, 2008 - 6...   Jan 17, 2008 - 6:33 PM
- - thespacepanda   That's pretty close to flush. Maybe a few more...   Jan 17, 2008 - 6:45 PM
|- - Penkka   QUOTE(thespacepanda @ Jan 17, 2008 - 6...   Jan 17, 2008 - 6:47 PM
|- - thespacepanda   QUOTE(Penkka @ Jan 17, 2008 - 11:47 ...   Jan 17, 2008 - 6:54 PM
|- - Penkka   QUOTE(thespacepanda @ Jan 17, 2008 - 6...   Jan 17, 2008 - 7:01 PM
- - thespacepanda   Nobody got it? Anybody? Alright, I'll go back ...   Jan 17, 2008 - 8:20 PM
|- - 6strngs   QUOTE(thespacepanda @ Jan 17, 2008 - 5...   Jan 17, 2008 - 9:34 PM
- - Daftboy   What size spacers should i get to get my wheels fl...   Jan 18, 2008 - 3:52 PM
|- - WannabeGT4   QUOTE(Daftboy @ Jan 18, 2008 - 2:52 ...   Jan 18, 2008 - 4:20 PM
|- - Penkka   QUOTE(Daftboy @ Jan 18, 2008 - 3:52 ...   Jan 19, 2008 - 6:27 AM
|- - 6strngs   QUOTE(Penkka @ Jan 19, 2008 - 3:27 A...   Jan 19, 2008 - 1:43 PM
- - Daftboy   15mm will not sit it flush i think.... i was think...   Jan 18, 2008 - 5:28 PM
|- - 6strngs   QUOTE(Daftboy @ Jan 18, 2008 - 2:28 ...   Jan 18, 2008 - 5:41 PM
- - WannabeGT4   I said 15mm because you're lowered. If you wer...   Jan 18, 2008 - 5:46 PM
- - Daftboy   Well if I went to 25mm I would get new bolts ...sa...   Jan 18, 2008 - 8:14 PM
- - 6strngs   25mm is almost one full inch, if when you put your...   Jan 18, 2008 - 9:37 PM
- - Daftboy   As he said.....plus the only way too get 8JJ for ...   Jan 19, 2008 - 2:15 PM
- - Culpable04   and if you live where you get snow and your celi i...   Jan 19, 2008 - 3:07 PM
- - Daftboy   with 15mm spacers do we need longer bolts? or shou...   Jan 20, 2008 - 3:00 AM
- - Culpable04   you'll need longer studs   Jan 20, 2008 - 3:05 AM
4 Pages V   1 2 3 > »
Lo-Fi Version Time is now: August 27th, 2026 - 12:33 PM
