Jan 11, 2006 - 7:19 PM
Enthusiast ![]() ![]() Joined Aug 30, '02 From NYC Currently Offline Reputation: 0 (0%) |
hey guys,
due to resources in parts and money i have decided to do the ST 185 swap rather than the ST205. I have done so much research on the ST205 that i have completely neglected looking into the ST185. I have tried the search and there is alot of scathered information on the 2nd gen swap, so im hoping that all questions and answers can be dedicated to this thread. so here are some question that i have: -what kinda tranny is best for this swap? will a sw20 mr2 tranny work? -what axles are needed if the tranny is swapped out? -what kinda modifications are needed to dropped the motor/tranny in? will it bolt right up? -what about the harness? does it plug in? -is there a big difference in the OEM motor and the JDM motor? does it make a difference during the swap? -what fuel pumps are you using as injectors? i know some of you guys completed this swap sucessfully, please give me your input. if it's not asking too much how about a write up on this. thanks for all the help |
Jan 11, 2006 - 7:43 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jul 5, '05 From Arlington, TX Currently Offline Reputation: 2 (100%) |
i would check out this webite for info and at the bottom - they have links to more info -
http://www.toyotacelicaonline.com/celica1/3sgteswap.htm This post has been edited by celicarus: Jan 11, 2006 - 7:47 PM |
Jan 11, 2006 - 7:45 PM
Jan 11, 2006 - 8:07 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
-------------------- ![]() I will return one day. |
Jan 11, 2006 - 9:13 PM
thanks for the links guys, helped alot.
i am looking to use a e153 tranny w/lsd. has anyone done this? i know the tranny and motor (st185) bolts right up but what about the axles?? if there is a better tranny option please let me know. the reason i want to use the e153 tranny is because of the clutch kit. other than the axles will there be any modifications to the tranny?? for those that have done it what is the common problem that you guys ran into?? thanks |
Jan 12, 2006 - 4:30 PM
anybody?
Jan 12, 2006 - 4:38 PM
Jan 12, 2006 - 4:41 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 21, '04 From New York City Currently Offline Reputation: 0 (0%) |
sorry alil off topic but weren't you deciding to sell your celi awhile ago? if you're keeping it glad you are. i'm in nyc too. i work in flushing queens. supersprynt have the e153 mr2t lsd tranny. pm him for info.
Jan 12, 2006 - 5:57 PM
i know some of you guys are also using 3sge trannies, which 3sge are you using (meaning out if which car). are they all the same?
Jan 12, 2006 - 5:58 PM
defgeph is using the 3sge tranny. pm him for more info.
Jan 12, 2006 - 9:50 PM
TRUE or FALSE?? about the 2nd gen 3sgte swap
-when you use the e153 tranny you do not have to modify the tranny? -the axles will have to be modified, using sw20 (mr2) inner axles and all-trac (90-93 st185) outers? -you can use 94-99 celica GT shifter cables with the e153 tranny? -GT motor mounts will work fine for the st185 and e153 set-up? thanks for the help |
Jan 13, 2006 - 1:42 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) |
-when you use the e153 tranny you do not have to modify the tranny? true
-the axles will have to be modified, using sw20 (mr2) inner axles and all-trac (90-93 st185) outers? true -you can use 94-99 celica GT shifter cables with the e153 tranny? true but i believe its better and feels more natural to use the st205 ones -GT motor mounts will work fine for the st185 and e153 set-up? false...the only mount u can use is the passengers side and possibly the front one from what i hear...but like i said just grab the st205 mounts and ur set bboy -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
Jan 13, 2006 - 6:02 PM
QUOTE(BBoYRuGGeD @ Jan 12, 2006 - 11:42 PM) [snapback]377958[/snapback] -when you use the e153 tranny you do not have to modify the tranny? true -the axles will have to be modified, using sw20 (mr2) inner axles and all-trac (90-93 st185) outers? true -you can use 94-99 celica GT shifter cables with the e153 tranny? true but i believe its better and feels more natural to use the st205 ones -GT motor mounts will work fine for the st185 and e153 set-up? false...the only mount u can use is the passengers side and possibly the front one from what i hear...but like i said just grab the st205 mounts and ur set bboy thanks for the info, as for the shifter cables, the GT and ST205 cables will work fine but the ST205 cables will be the perfer ones to use. I know the GT cables bolt straight up so how about the ST205 cables?? do you need any type of modification for them to work?? thanks |
Jan 14, 2006 - 6:17 PM
for those using the GT tranny and st185 motor, just curious on what clutch are you using?
This post has been edited by SilverCell94: Jan 14, 2006 - 6:17 PM |
Jan 15, 2006 - 12:03 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
Generally, people use a stock 5SFE clutch disc, with a 3SGTE pressure plate and throwout bearing. This works fine, but technically doesn't make use of all the room on the 3SGTE flywheel face, so some people order a custom clutch kit from a company called "Spec" (I think), basically it's a 3SGTE clutch with splines on disc to match the GT tranny input shaft.
-Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Jan 23, 2006 - 10:24 PM
thanks for the info
just an out of the blue question, what is an easier swap?? ST185 or ST205?? |
Jan 23, 2006 - 11:13 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 3, '05 From Tampa, Florida Currently Offline Reputation: 2 (100%) |
st185 more people have done it....
-------------------- I'am Reinventing the SLow Lane.....
| Lo-Fi Version | Time is now: August 27th, 2026 - 11:09 AM |
