Jan 12, 2006 - 5:46 PM
Enthusiast ![]() ![]() Joined Aug 30, '02 From NYC Currently Offline Reputation: 0 (0%) |
i know that the KOYO radiator bolts up to the GT but will it work for the ST? has anyone done this?
Jan 12, 2006 - 5:49 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 21, '04 From New York City Currently Offline Reputation: 0 (0%) |
it depends if you're gonna use it for a 7afe or the 3sgte that you intend to swap. it will fit but it will not work with the 7afe
Jan 12, 2006 - 5:52 PM
QUOTE(shin @ Jan 12, 2006 - 3:49 PM) [snapback]377740[/snapback] it depends if you're gonna use it for a 7afe or the 3sgte that you intend to swap. it will fit but it will not work with the 7afe so the koyo rad will work with the 2nd gen 3sgte on a Celica ST |
Jan 12, 2006 - 5:57 PM
yes. it will work with a 3sgte. it will fit regardless if it's a ST or GT.
Jan 12, 2006 - 9:20 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
QUOTE(shin @ Jan 12, 2006 - 2:49 PM) [snapback]377740[/snapback] it depends if you're gonna use it for a 7afe or the 3sgte that you intend to swap. it will fit but it will not work with the 7afe Umm it will work for the 7afe, i have one for it, but its not installed. (may need custom mounts or tubes, but theres no reason it wouldnt work for any manuel car.) |
Jan 12, 2006 - 10:24 PM
the GT radiator has a different return location, all you need is to add another hose to connect it to the block.
Jan 16, 2006 - 1:53 AM
Enthusiast ![]() ![]() Joined May 24, '03 From Andrews TX Currently Offline Reputation: 1 (100%) |
I have one on my ST w/ a 7AFTE and I am also doing a swap to a '93 st185 RC and it should be fine
the only problems I had were 1.lower radiator hose I have a universal bendable peice(you can get at autozone, advance autoparts), but plan on getting an aluminium line for return 2.hole on passenger side of radiator where the GT has a temp. sensor, and ST does not I bought a GT temp. sensor to plug it and I am planning on wiring the sensor to kick on my fans 3.I bought on of the C.F. cooling panels from the group buy not too long ago and it would not fit I just had to cut off about 3/4" off of the side closest to the radiator and that was all that was needed This post has been edited by dans_st: Jan 16, 2006 - 1:54 AM -------------------- If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
Jan 16, 2006 - 1:59 AM
i think to make it work on a swap will really depend on what downpipe yo have and how your intercooler piping is all setup.
on my car, the stock radiator fans are very close to my 3in downpipe and ic piping. so if i wanted to install one, i would either have to do some creative triming from the fans plastic suppors, or find lower profile fans. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 16, 2006 - 10:54 PM
or you could put some "pusher" fans on the other side instead, you can find some at autozone for around $18ea.
| Lo-Fi Version | Time is now: June 14th, 2026 - 1:54 AM |
