Jan 12, 2006 - 11:21 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 9, '03 From St. Louis Currently Offline Reputation: 0 (0%) |
obviously some newer cars have larger wheels, some are 17inch and they don't have low profile tires. Is there anyway I can put non-low-profile tires on my 17 inch motegis? Can I have the speedometer adjusted to compensate for the added diameter? I want more or a sidewall, and I actually like the look of taller wheels.
-------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
Jan 13, 2006 - 2:25 AM
ok, well, I'm sure I could easily find this answer from a local autotire. I was just hoping to get an answer from the comfort of my own room.
Jan 13, 2006 - 8:11 AM
yes you can have your speedometer recaliprated but it will cost you some amount...
and for tires you can fit a 45 probably even a 50 since your not lowered...well your pics don't show a drop so ehh....should just look at tire rack This post has been edited by playr158: Jan 13, 2006 - 8:24 AM |
Jan 15, 2006 - 3:02 AM
Enthusiast ![]() Joined Jan 6, '06 From Toronto, Canada Currently Offline Reputation: 0 (0%) |
Why do you care so much that your speedometer wont be accurate anymore. You can easily figure out how much your speedometer will be affected. So when ur speedometer will say 100km/h you will know that you are going 102 or 103 for example. Id get like 225/45/17 and dont worry about your speedometer.
Jan 15, 2006 - 3:13 AM
QUOTE Id get like 225/45/17 and dont worry about your speedometer. agreed, the speedo what be a problem and youll get good ride quality -------------------- 15PSI - 30MPG - Megasquirt Tuned
| Lo-Fi Version | Time is now: August 26th, 2026 - 9:50 PM |
