Aug 21, 2009 - 1:44 PM
Enthusiast ![]() Joined Jul 11, '09 From UK Currently Offline Reputation: 2 (100%) |
burneeed, please take this picture, save it on your hard drive and edit it with paint brush to tell us exactly what you cut. Mark it in blue or some other color than red ------------ NOTE: this picture has already a red 1/2" mark on it that i put in there for a ealier post -------------------- ![]() don't know what everyones problem is withthis picture it makes perfect sense. 1/2" metal ring highlighted in red.. cut it off the axle, you then have a 1/2 spacer easy peasy. |
Apr 22, 2010 - 5:29 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
Ok im gonna be an idiot here and ask..
im swapping a 3vzfe with its stock e53 (same case and dif spline as e153) out of a 92 es300 (same as a camry v6) early 90s camry/es300 has the same size spline as the celica... can i use the stock axles!? since im using the motor/tranny combo that matches stock, the carrier bearing lining up ISNT a problem. -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Apr 22, 2010 - 7:02 PM
i dont think so. it all has to do with the placement of the E-153. because of its particular shape you need a slightly longer axle on the passenger side
Apr 22, 2010 - 9:14 PM
the es300/camry is 3.3 inches wider than the celica...
Apr 23, 2010 - 7:29 AM
btw i meant stock as in stock camry v6 axles
Apr 23, 2010 - 9:06 AM
if the axle will mount to the stock celica hub, if their splines match, then i think it will work. i dont know if the camry uses a idler bearing like the celica does. i cant remember since i just did a clutch job on a solara
| Lo-Fi Version | Time is now: September 11th, 2026 - 11:48 AM |
