13 Pages V  < 1 2 3 4 5 > »
> The MR2T tranny "short axel" solution, For those that want to know...
post Feb 14, 2006 - 11:40 PM
I contaced them, never got a response.
post Feb 15, 2006 - 6:29 AM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(lagos @ Feb 14, 2006 - 8:55 PM) [snapback]394019[/snapback]
umm that looks like the same sh1t. maybe all mr2 axels look like this?
post Feb 15, 2006 - 6:36 AM
ouch, erik that looks stretched!
now i see what you guys are talking about..lol
looks like using that "ring" as a spacer works pretty well...maybe a machined peice to replace it almost like a wheelspacer would work?
post Feb 15, 2006 - 8:02 AM
Jay is your car jacked up in that pic?
post Feb 16, 2006 - 7:00 AM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(Supersprynt @ Feb 15, 2006 - 7:02 AM) [snapback]394234[/snapback]
No.
post Feb 26, 2006 - 7:50 PM
scothaniel
Joined May 1, '03
From Michigan
Its 2 All-Trac CV housings for sure (outer-race for the proper name).
I bought a trashed 185 outer shaft from a buddy, separated the outer-race and added it between the MR2 inner and current 185 outer - absolutly perfect fit!
If anyone else is going to do this, be sure to have a set of 10mm x 1.5 - 90mm socket head bolts on hand, as hex-head bolts will hit the sides of the axel.
Scott
West Michigan
post Feb 26, 2006 - 8:11 PM
Nice, I should have my outer's lying around somewhere, just gotta get new MR2 axle and im good.
post Mar 2, 2006 - 12:42 AM
Green_MachToy
Joined Mar 21, '04
From Oceanside
Yeah - this works great! I took the outer portion that bolts up to the MR2 inner...second one off of a "spare" st185 or v6 axle. I went down to the hardware store spent 10 bucks (got extra bolts just in case). Made sure to line them up so the channel on the inside does not allow the ball bearings to slide all the way into the "spare" spacer. Made that mistake once! Bolted it up and was good to go! I've been running with mine for over a year! By the way anyone ever look at a Camry V6 axle and a ST185 - when I did, they looked the exact same. So unless they are made of different grades or something I didn't notice...they appear to be the same!
Thanks this was a great note!
This post has been edited by Green_MachToy: Mar 2, 2006 - 12:45 AM
post Mar 25, 2006 - 11:30 PM
celica3sgte
Joined Nov 12, '02
From Columbus, Ohio
Just for reference, the difference between the camry and st185 axle is the outer end with the spline. The splines are different. It won't fit into the celica hub.
post Mar 26, 2006 - 7:05 AM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(celica3sgte @ Mar 25, 2006 - 10:30 PM) [snapback]413231[/snapback]
Kuya1284 (board name) used v6 camry axels without problems.
Second entry in completed engine swaps
post Mar 26, 2006 - 7:33 AM
ems3s
Joined Jun 17, '05
From Melbourne, Australia
QUOTE(jgreening @ Mar 26, 2006 - 10:05 PM) [snapback]413320[/snapback]
Early model camry v6's ~'90 have the same outer spline as st204 but later model camry ~'95(more common now) have larger splines. sorry had to clear that up. Having done the conversion twice now, I've learnt that people should be more specific with quotes and advice, cos it gets costly when you order wrong parts.
On a separate matter I think that people are using two left st185 shafts in their 204's cos I havent had any problems with my shafts popping out.
I have spoken to several wreckers in my area who swear that both shafts are same but they're clearly not. There is about an inch difference between the two. Anyway not trying to sidetrack this thread but thought it may explain the problem.
post Mar 26, 2006 - 7:39 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
post Mar 26, 2006 - 11:10 PM
scothaniel
Joined May 1, '03
From Michigan
According to Toyota they are the same. Same part number in the EPC, and the last set I ordered for my AllTrac were listed only as being for the front.
Scott
West Michigan
post Apr 1, 2006 - 3:54 PM
Jay can you take a pic of your drivers side also?
QUOTE(Green_MachToy @ Mar 2, 2006 - 12:42 AM) [snapback]401673[/snapback]
Can you go into more detail about lining the channel up and the ball bearings?
Did you get socket cap head bolts like the originals or go with just Hex head? I have been unable to find the same type of bolt but 2'' longer.
This post has been edited by Supersprynt: Apr 2, 2006 - 1:03 PM
post Apr 1, 2006 - 7:02 PM
Here is the piece that seperates from the axle that can be used as a spacer - i havent put it altogether yet
post Apr 1, 2006 - 7:05 PM
ILuvMyCelica95
Joined Dec 16, '02
^ yeah i take good pics.
post Apr 3, 2006 - 8:11 PM
Green_MachToy
Joined Mar 21, '04
From Oceanside
I have a few extra bolts if you need them. They are exactly like the originals only longer. I am not too great and getting th epics in here, but I will give it a shot.[link]http://community.webshots.com/myphotos?action=showPhoto&albumID=549177188&photoID=2191449550058659770&security=gdjWAa[/link][link]http://community.webshots.com/myphotos?action=showPhoto&albumID=549177188&photoID=2127861520058659770&security=WWuNAN[/link][link]http://community.webshots.com/myphotos?action=showPhoto&albumID=549177188&photoID=2052941580058659770&security=qJLpRF[/link]
I was just trying to say, when you put the second "spacer" up against the first space that is already on the axle with the boot, make sure the channels on the inside do not line up. If you place the second spacer on the bolts and notice that the channels flow smoothly all the way through...stop and flip the second one over. THis should put a ridge in the way of the channel and everything will work fine.Axle without second spacer
This post has been edited by Green_MachToy: Apr 3, 2006 - 8:13 PM
post Apr 3, 2006 - 8:18 PM
Your pics arent really working in the forum but do work.... I have been looking all over for those bolts and nobody has those so I was goign to just use hex had Grade 8s. Where did you find yours?
[img]http://image48.webshots.com/49/4/49/55/2191449550058659770gdjWAa_ph.jpg
[img]http://image48.webshots.com/48/8/61/52/2127861520058659770WWuNAN_ph.jpg
[img]http://image38.webshots.com/39/9/41/58/2052941580058659770qJLpRF_ph.jpg
This post has been edited by Supersprynt: Apr 3, 2006 - 8:21 PM
post Apr 3, 2006 - 10:47 PM
erik go to www.mcmaster.com you'll probably be able to find the stuff you need there they have practically everything
and me FTW:
This post has been edited by playr158: Apr 3, 2006 - 10:48 PM
post Apr 3, 2006 - 11:29 PM
thats what u think.
Lo-Fi Version Time is now: September 11th, 2026 - 11:48 AM
