> ppl with the momo hub, horn????
post Jan 12, 2006 - 11:49 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
i've jus installed some aftermarket steering wheels..and it looks nice.....the problem is that i the spiral "cable" doesnt fit over the hub..i ended up takin it off.....now im runnin witout hrons.....any1 install theirs with horn still workin?...momo came wit a wire but it doesnt reach over the hole to which the OEM horn wire is....some1 plz help...
post Jan 13, 2006 - 12:24 AM
soven
Joined Mar 14, '05
From Auckland,New Zealand
not that I have fitted a momo wheel but can't you just extend the wire?
post Jan 13, 2006 - 9:33 PM
yungazzdriver
Joined Feb 15, '05
From Frederick, Maryland
yeah i got the same prob i got the momo hub and i cant find a way to hook it up
post Jan 14, 2006 - 12:23 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
QUOTE(yungazzdriver @ Jan 13, 2006 - 9:33 PM) [snapback]378456[/snapback]
so u dont have teh horn n the turn signal retracker?
post Jan 14, 2006 - 1:28 AM
yungazzdriver
Joined Feb 15, '05
the turn signal retracter always works regardless or atleast for me it does,..............but nope not da horn i can live without it cuz i aint much of a honker n-e wayz
post Jan 14, 2006 - 11:33 AM
shin
Joined Aug 21, '04
From New York City
mine is hooked up with the horn still working.. all i did was extend the green wire
~*MuH NeW RiDe*~
post Jan 14, 2006 - 2:24 PM
Hanyo
Joined Aug 16, '03
From Bay area
yea i had to do the same thing.
Make sure you extend the wire with alot of slack because this wire will be twisting all the time.
post Jan 14, 2006 - 11:43 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
im confused guys confused.gif i tried fitting the hub over the retracter..and it doesnt fit....the connector for which the horn was blocking the hub...how u guys manage to fit over that?....
as for the green wire for the horn..ill try to extend it .. jus have to take it out n take another looksy....
post Jan 15, 2006 - 3:47 AM
Hanyo
Joined Aug 16, '03
From Bay area
you have to remove the retractor, and run the wire up through the hub.
post Jan 16, 2006 - 12:03 AM
yungazzdriver
Joined Feb 15, '05
is the retractor the yellow thing that hooks up to the airbag????????..............if so then yeah you gotta remove it innorder to fit the hub adapter!!! and makes sure you dont forget the position of the steering wheel.........(its like putting your motor to top dead center) just line up the steering wheel before you take it off and check the tires if they are str8 then your set, take off your steering wheel,(stock) then put the steering wheel on the hub adapter,then put it on the mount area and then bolt it on, then put the horn on (some how i unno how to) and enjoi!!!!!
post Jan 16, 2006 - 1:58 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
yea the retractie is that yellow thing that rotates...i was thinkin if i cut off one lil section off maybe itll fit.....jus a thought...
man i really need the horn.....tonight i was waiting for a parkin space in walmart n this guy keeps backin up closer n closer.....then when he was like couple inches from my car..i jus gun off and look for another spot...horn is so important especially when idiots like that drivin round......
the horn has two female connectors on the back of the steering wheel....ive tried extending the green wire ... well not actually, i jus put in a wire to the connector n extend that wire to one of the connectors on back of the steering wheel..and one wire that came with the momo hub..still to no conclusion.....guys...wit momo how u guys wire your horn up?...
post Mar 2, 2007 - 4:20 AM
Alan
Joined Jan 23, '05
From Malta
QUOTE(DeW_H0e_GT @ Jan 16, 2006 - 1:58 AM) [snapback]379195[/snapback]
I have that problem with My horn but i am just going to buy a Sparco one there much better wink.gif
Lo-Fi Version Time is now: June 23rd, 2026 - 1:56 AM
