Jan 13, 2006 - 2:18 AM
Enthusiast ![]() ![]() Joined Apr 24, '04 From S. Cali Currently Offline Reputation: 0 (0%) |
Will i lose my A/C when i swap in the 3s?
If i do have to remove it, is there any way of putting it back? |
Jan 13, 2006 - 2:27 AM
the ac bolts up and everything hooks up to it. if it still works after your swap will depend on two things. 1, if the person who did you harness wired up the ac correctly, and 2, if didnt discharge your ac when you swaped.
mine has not worked since the swap, but i never got around to refilling it or trying to check the wiring. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 14, 2006 - 1:15 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
The a/c works just fine on the last 3SGTE I did
-Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Jan 14, 2006 - 2:09 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) |
^^^ yap... mine works just fine
bboy -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
Jan 14, 2006 - 2:17 AM
ill have to get mine bleed and refilled to see if it works
Jan 15, 2006 - 3:14 AM
Enthusiast ![]() Joined Jan 6, '06 From Toronto, Canada Currently Offline Reputation: 0 (0%) |
QUOTE(Dr_Tweak @ Jan 14, 2006 - 1:15 AM) [snapback]378542[/snapback] The a/c works just fine on the last 3SGTE I did -Doc Mine doesnt turn on either. I believe it has something to do with wiring. The compressor never turns on when I push A/C. How did you wire up your last swap. |
Jan 15, 2006 - 3:25 AM
QUOTE(Speedy2k @ Jan 15, 2006 - 8:14 AM) [snapback]378911[/snapback] QUOTE(Dr_Tweak @ Jan 14, 2006 - 1:15 AM) [snapback]378542[/snapback] The a/c works just fine on the last 3SGTE I did -Doc Mine doesnt turn on either. I believe it has something to do with wiring. The compressor never turns on when I push A/C. How did you wire up your last swap. It's a little complicated, who did the wiring for your swap? This post has been edited by Dr_Tweak: Jan 15, 2006 - 3:25 AM -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Jan 16, 2006 - 2:17 AM
I actually got a 5th gen and I did the wiring myself. I actually dont have the 3rd plug plugged in on the ECU. So I dont have the engine light and no A/C. Last summer was brutal!
Jan 16, 2006 - 6:13 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
QUOTE(lagos @ Jan 13, 2006 - 7:27 AM) [snapback]377972[/snapback] the ac bolts up and everything hooks up to it. if it still works after your swap will depend on two things. 1, if the person who did you harness wired up the ac correctly, and 2, if didnt discharge your ac when you swaped. mine has not worked since the swap, but i never got around to refilling it or trying to check the wiring. If you cant get it working i would recomend getting rid the pump like i did, that think is really heavy. That combined with removing the stock downpipe will shave about 40 lbs give or take from the engine bay. Just get a shorter alternator belt and your good. |
| Lo-Fi Version | Time is now: August 26th, 2026 - 8:48 PM |
