Jan 13, 2006 - 6:26 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
OK, While tearing the engine down I came acrossed something. While taking the rod caps off I noticed that the #1 and #4 caps where different then the #2 and #3. My question is should they be different, or did someone take my engine apart once and put it back together wrong?
On the connecting rods you have the little notches that the bears that allow them to seat. To my understanding those notches should be facing oppisite ends. They are on the #2-#3 rods. The #1-#4 rods they are facing each other. Is this something Toyota does or did someone put them in wrong? I can post pictures if I am not clear of my question. Thank you. This post has been edited by Jaws4God: Jan 28, 2006 - 11:25 AM -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Jaws4God Rebuilding Engine Questions... Jan 13, 2006 - 6:26 PM
Jaws4God we also just noticed that the top of the block has... Jan 16, 2006 - 11:34 PM
Jaws4God I think we might get to assembling tomorrow and i ... Jan 18, 2006 - 9:59 PM
Jaws4God Well the engine is back in... but went to start it... Jan 27, 2006 - 5:57 PM
Jaws4God We reset the timing... but it may be off a notch..... Jan 31, 2006 - 9:28 PM
macavely are you following the toyota rebuild manual ? Jan 31, 2006 - 9:33 PM
Jaws4God i have a hans manual... we tried to follow everyth... Jan 31, 2006 - 9:34 PM
macavely well you found the timing problem .. i'm asumi... Jan 31, 2006 - 9:37 PM
Kwanza26 Check your timing again. If the car doesn't c... Jan 31, 2006 - 10:11 PM
Jaws4God thank you... this is the kinda help we need... if ... Jan 31, 2006 - 10:27 PM
macavely recheck all the ignition system wires... a lose on... Jan 31, 2006 - 11:43 PM
DJWashington Check your timing again. Then check spark on all f... Feb 1, 2006 - 6:20 PM
Jaws4God Thank you.. I hope to work on it tomorrow... I... Feb 1, 2006 - 11:49 PM
soulshadow Heres one thing, Do not use the book as a guide bu... Feb 2, 2006 - 9:35 AM
Jaws4God i was looking through the haynes manual troublesho... Feb 2, 2006 - 11:51 AM
SlowCelica94 Are you getting fuel pressure? Buy a $30 fuel... Feb 2, 2006 - 12:46 PM
Jaws4God update... just wanted to let ya all know the car i... Feb 6, 2006 - 1:05 AM
hitcachi If it was making a clicking noise then yes it is m... Feb 7, 2006 - 1:47 PM
Jaws4God well i took the car on the highway the other day..... Feb 21, 2006 - 2:55 PM
nightryder after my swap ive been having that same problem wi... Feb 21, 2006 - 8:34 PM
Jaws4God QUOTE(nightryder @ Feb 22, 2006 - 1... Feb 21, 2006 - 10:13 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 21st, 2026 - 8:42 PM |
