> worn out CV boots
post Jan 14, 2006 - 8:33 AM
ToysRfast
Joined Dec 11, '05
From MN, Rochester
The CV boots right and left side are bad. The car starts to shake when I go faster then 60MPH and The car makes loud clicking sounds when I make left and right turns. The car also lost a lot of its power when I put the car in 1st gear it barely even moves. Everyone says the clutch burned out. I never smelled the clutch burn out and the clutch pedal is still stiff like it was when I bought my Celica. Anyway I placed an order for Inner and outer CV boot kits. With the problems I'm haveing do you guys think I should consider new Drive shafts? Would the loss of power be from the drive shaft or the Clutch?
Lo-Fi Version Time is now: August 31st, 2026 - 10:41 PM
