> rear disc brake caliper part numbers?
post Jan 14, 2006 - 11:59 AM
25thcelica
Joined Oct 11, '04
From Silver Spring Maryland
hey guys I just got some 4th gen gts rear disc brake parts to do a drum to disc swap I was wondering if anyone had part numbers to the actual 6th gen parts so I could match them up to see if they will work.
Fernando
Replies (1 - 2)
post Jan 17, 2006 - 1:01 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
The rear calipers between 4th gen, 5th and 6th gens, along with Camrys are the same thing. They all use the same brake pads. There are minor differences between the caliper brackets, but it's mostly superficial. What's different, are the internal drums...
post Jan 28, 2006 - 9:43 AM
25thcelica
Joined Oct 11, '04
thanks Kwanza26 I will look into it more to see if I can make the internal drum brake part work or if it is the same thing.
Fernando
Lo-Fi Version Time is now: August 27th, 2026 - 10:48 PM
