> chargecooler
post Jan 16, 2006 - 5:30 PM
dan4
Joined Apr 23, '05
From kent
right i have trawled for weeks now to find out how to get the st205 IC pump to run constantly. i know i could just put a live feed and earth to it and run it off a switch but its my understanding that its connected to the ecu and will therefore put the engine check light on. Someone please help me...!!!!!
oh and for a nice easy mod on the stock st205 chargecooler clean out with petrol or a very high quality de greaser and apply heat shielding to the underside and you will see charge temps drop dramatically.... i was seeing 50-55 deg centigrade at 1.1 bar of boost and a ambient temp of about 7degrees centigrade, i am now seeing 30-35 at the same boost pressure and same ambient temp and i am yet to finish the heat shielding properly. NOTE when you flush the chargecooler, if there was a fair amount of oil in there it will smoke heavily as the deposits gradually work their way out. biggrin.gif biggrin.gif biggrin.gif
post Jan 16, 2006 - 5:42 PM
http://celicatech.com/forums/showthread.php?t=11119
that should help you .
post Jan 16, 2006 - 5:45 PM
dan4
Joined Apr 23, '05
From kent
i dont think you understood fully.... i dont have a code 54 showing up as i already have the chargecooler level sensor bridged. i am after information as to how to get the pump to run constantly without an ecu error code....
post Jan 16, 2006 - 5:53 PM
I have the pump running off my ignition switch - always on when the cars on.
post Jan 16, 2006 - 5:57 PM
dan4
Joined Apr 23, '05
From kent
how do you stop the ecu error code 54 appearing?!
dan4
Joined Apr 23, '05
From kent
post Jan 16, 2006 - 9:20 PM
I have an ST185 3s w/ST185RC intercooler so I dont get a code 54.
post Jan 16, 2006 - 9:24 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
you need to ground a pink wire on your ecu. Thats for the 185rc ecu anyway.
i think its the win pin
I will return one day.
post Jan 16, 2006 - 9:33 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
link
post Jan 17, 2006 - 12:14 PM
dan4
Joined Apr 23, '05
From kent
right i have the wiring diagram which shows three wires from ecu to pump. they are M+, M-, and MTT you dont have any idea what the pink wire was on your 185??? it wil give me a good shove in the right direction
post Jan 17, 2006 - 1:18 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
I'm not sure what to ground on the 205. Maybe Wannabe will see this thread, he might be able to shed some light
Good luck
post Jan 17, 2006 - 2:09 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(defgeph @ Jan 17, 2006 - 12:18 PM) [snapback]379866[/snapback]
Good luck
I'll try and remember to look when I get home.
post Jan 17, 2006 - 3:43 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Splice into the blue wire on the 26 pin ECU connector (when lookin at the back of the connector it's the 5th from the left on the bottom row) and run a wire to ground. That should allow the ECU to think it's functioning normaly. However, I couldn't find out what the function of the M+, M-, or MTT wires were. If they are there to sense that the pump is running when it shouldn't, then it will probably throw a code. If that is the case, we'll have to come up with something else. It could be as simple as one or two relays.
post Jan 18, 2006 - 8:43 AM
dan4
Joined Apr 23, '05
From kent
this might help understand, i havent really had a chance to study it fully yet myself
http://www.st205.net/techinfo/ewd/ewd2b.jpg
post Jan 18, 2006 - 10:15 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
I found this scan to be quite helpful as well:
http://www.st205.net/techinfo/205turbocircuit.jpg
Go ahead and try it and see if it works without throwing a code. If you do get a code I'm sure we could figure out something else.
post Jan 22, 2006 - 10:13 AM
dan4
Joined Apr 23, '05
From kent
back to the drawing board methinks. earth the blue wire and after 30secs the light comes on (prob when the ecu is trying to turn the pump off???)
post Jan 22, 2006 - 10:29 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
I was afraid of that. If you can measure the voltage of M+, M-, and MTT when the pump is running and when it is stopped with the stock wiring configuration, we can probably figure this out pretty easily. Hopefully it's a simple voltage output that we can interupt with a relay so that it thinks it's off when it's supposed to be.
post Jan 22, 2006 - 10:34 AM
dan4
Joined Apr 23, '05
From kent
same idea as i had although i ran out of light and patience yesterday. ill see whats happening at those terminals
Lo-Fi Version Time is now: August 27th, 2026 - 1:59 AM
