May 20, 2003 - 3:14 PM
Enthusiast Joined May 15, '03 From michigan Currently Offline Reputation: 0 (0%) |
I just pulled my guages out to install my indiglos and I need to know what wire to splice into to light em up when the headlights are on... '95 celica st auto
May 20, 2003 - 4:13 PM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 30, '02 From Franklin,Tn Currently Offline Reputation: 0 (0%) |
OK, there's a how to on this install, in the how to section. Its preaty straight forward on the install.
Bryan |
May 21, 2003 - 12:38 AM
Enthusiast ![]() Joined Nov 8, '02 From New Zealand Currently Offline Reputation: 0 (0%) |
Hi
I took the easy way and ran the wires down and then through the plastic centre column (you can just tuck them underneath, no need to remove it) to the cigarette lighter. It has a ring that lights up when the lights are turned on, so I just connected the indiglo wires to the +ve and -ve cables that power that light (make sure it's the light connections and not the lighter connections). The plastic panel the cigarette lighter is attached to just pops out. My cables were long enough and it meant i didn't have to try and find the right wire to spice or unscrew/remove any major panels. Hope this helps -------------------- ![]() |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 7:08 AM |
