> 3sgte 5sfe clutch. help.
post Jan 17, 2006 - 4:37 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
alright. im using the stock 5s tranny. on the 3s.
the 5s pressure plate is slightly smaller than the 3s.
same with the clutch disk.
so i guess from what i read. i use a 3s pressure plate (duh) with a 5s clutch disk.
so how do i go about getting this combo? i was thinking to save money i could use the stock 3s pressure plate with an aftermarket 5s disk. so all i would have to buy is the disc. any thoughts?
Replies (1 - 4)
post Jan 17, 2006 - 4:45 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
http://cgi.ebay.com/ebaymotors/ACT-4Pad-Ra...sspagenameZWD1V
check it out 4 puke clutch disc for a 5sfe $89 bucks!
then i use that with the stock 3s pressure plate.
make sense? or u think i could damage the pressure plate. i doubt it since nothign really changes on them between clutch stages it seems to only be the disc. hmmmmm.
http://cgi.ebay.com/ebaymotors/ACT-6Pad-Ra...sspagenameZWD1V
or a 6 puke for $99 hmmmmmmmmmmmmmm.
This post has been edited by x_itchy_b_x: Jan 17, 2006 - 4:48 PM
post Jan 17, 2006 - 4:57 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
I dont think its a good idea to mix and match old clutchs with new disks.
Try to dig up some money, Or charge it for now. pay it back later.
Call spec get the kit.
I will return one day.
post Jan 17, 2006 - 5:41 PM
if u mix and match used and old...your just asking for trouble. you cant half ass this like your 5sfTe..lol
if u call up a place like spec, they can make you a custom 3sgte disk (the correct diamiter for the flywheel) but with the splines for the 5sfe tranny. then get the 3sgte PP, and the 5sfe TO bearing and alignment tool.
STAY AWAY from a 4puck. it will make driving a horror. the act 6 puck is ok, but it dosnt have any springs. its not going to be as fun to drive as something like a sprung 6 puck spec. dont go any higher then a sprung 6 puck. a spec stage 2 or 3 is what u want
if you dont have the money to do it right, borrow some from mom
This post has been edited by lagos: Jan 17, 2006 - 5:46 PM
post Jan 17, 2006 - 9:07 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
yeah. true story. im gunna wait for tax returns and get a kit from spec.
Lo-Fi Version Time is now: August 27th, 2026 - 1:02 AM
