> Oil pressure on 7AFE
post Jan 19, 2006 - 12:04 AM
southwest2118
Joined Jan 13, '06
any body know the oil pressure i should be getting at the TEE next to the filter on the 7AFE? around what?
- southwest2118   Oil pressure on 7AFE   Jan 19, 2006 - 12:04 AM
- - trd94   QUOTE(southwest2118 @ Jan 19, 2006 - 12...   Jan 19, 2006 - 1:27 AM
- - Batman722   from the BGB the oil pressure is around 3.8 to 71 ...   Jan 19, 2006 - 1:33 AM
- - southwest2118   whats BGB?   Jan 20, 2006 - 8:00 PM
|- - Batman722   QUOTE(southwest2118 @ Jan 20, 2006 - 8...   Jan 20, 2006 - 10:41 PM
- - playr158   big giant book.....toyota's handbook on the ce...   Jan 20, 2006 - 10:37 PM
- - CheesyLobster   i get 45 or so at startup/ under throttle. At rest...   Jan 20, 2006 - 11:32 PM
- - Dr_Tweak   45 is right around where you want it when warmed u...   Jan 20, 2006 - 11:35 PM
- - southwest2118   at start up i get like 50 and under throttle its l...   Feb 6, 2006 - 7:20 PM
|- - Batman722   QUOTE(southwest2118 @ Feb 6, 2006 - 7...   Feb 6, 2006 - 11:04 PM
- - southwest2118   -3an piping or Restrictor ??   Feb 7, 2006 - 7:15 AM
- - southwest2118   ??? its for a rebuilt t3 .42/.48 A/R??   Feb 10, 2006 - 11:46 PM
- - Dr_Tweak   They say you're supposed to use a restrictor i...   Feb 11, 2006 - 1:46 AM
- - southwest2118   come on doc what do you do?   Feb 11, 2006 - 1:52 AM
- - Dr_Tweak   It's on a case by case basis. I buy the restr...   Feb 11, 2006 - 2:44 AM
|- - presure2   QUOTE(Dr_Tweak @ Feb 11, 2006 - 2:44...   Feb 11, 2006 - 8:29 AM
- - southwest2118   at WOT I'm at 60 psi....so i should try just r...   Feb 11, 2006 - 3:01 AM
|- - Dr_Tweak   QUOTE(southwest2118 @ Feb 11, 2006 - 8...   Feb 11, 2006 - 3:07 AM
- - southwest2118   other then the internet where can i get those size...   Feb 11, 2006 - 3:15 AM
|- - Dr_Tweak   QUOTE(southwest2118 @ Feb 11, 2006 - 8...   Feb 11, 2006 - 3:53 AM
- - southwest2118   how do i know what the wastegate is set to?..........   Feb 11, 2006 - 3:56 AM
- - Dr_Tweak   Normally you find out from whoever you buy the tur...   Feb 11, 2006 - 3:58 AM
|- - southwest2118   ****....let me sleep on it QUOTE(Dr_Tweak ...   Feb 11, 2006 - 4:10 AM
- - southwest2118   you think this will work PN# EAR-981603ERL x2 on h...   Feb 11, 2006 - 3:59 AM
- - Dr_Tweak   Yeap you'll need two of those and two of these...   Feb 11, 2006 - 4:03 AM
- - southwest2118   2-EAR-600103ERL Fitting, Hose End, Speed-Seal, St...   Feb 11, 2006 - 4:16 AM
- - Dr_Tweak   http://store.summitracing.com/partdetail.a...15...   Feb 11, 2006 - 4:18 AM
- - southwest2118   will i need to retard timming if i use a ?safc2? a...   Feb 11, 2006 - 4:20 AM
- - southwest2118   what if i get rid of the 2 x speed seal end pieces...   Feb 11, 2006 - 4:23 AM
- - Dr_Tweak   QUOTE(southwest2118 @ Feb 11, 2006 - 9...   Feb 11, 2006 - 5:32 AM
- - southwest2118   where do i buy a -3an oil feed line for my turbo? ...   Feb 14, 2006 - 1:42 AM
- - Dr_Tweak   If it's a stainless braided -3 AN line, then i...   Feb 14, 2006 - 2:10 AM
|- - southwest2118   QUOTE(Dr_Tweak @ Feb 14, 2006 - 1:10...   Feb 14, 2006 - 7:12 AM
- - presure2   if your making it yourself, you need to buy a pres...   Feb 14, 2006 - 7:49 AM
- - Smokeeey420   or just buy a t3/t4 oil feed line kit for like ...   Feb 15, 2006 - 10:13 PM
- - normality78   sorry for to bring this thread back alive since ne...   Jan 1, 2007 - 4:24 AM
- - presure2   it seems like everyone who turbos the 7a has the p...   Jan 1, 2007 - 6:15 PM
|- - normality78   QUOTE(presure2 @ Jan 1, 2007 - 6:15 ...   Jan 1, 2007 - 8:49 PM
- - OOBE   I've had to rebuild my turbo every year and it...   Jan 1, 2007 - 9:38 PM
- - Bitter   jeeze guys, its a KNOW ISSUE that the 7afe has hig...   Jan 2, 2007 - 1:09 AM
- - OOBE   Well thanks for enlightening us with your knowledg...   Jan 2, 2007 - 1:50 AM
- - normality78   ok. got it thn. Tks for it   Jan 2, 2007 - 2:41 AM
- - southwest2118   i ran a restrictor for about two months till it br...   Jan 4, 2007 - 7:51 PM
Lo-Fi Version Time is now: June 9th, 2026 - 7:21 AM
