> N2o NOS ZEX NX, what do you think????
post Jan 19, 2006 - 10:43 AM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
NX express, ZEX, NOS has any have some on there car ???? gonna put some on my new motor only a 50 shot...
Replies (1 - 19)
post Jan 19, 2006 - 11:50 AM
post Jan 19, 2006 - 11:51 AM
if your 3s swapping there is no need for Nitrous
post Jan 19, 2006 - 11:54 AM
jgreening
Joined Jan 17, '04
From Illinois
I have done a fair amount of reading about the topic lately and I am of the opinion if its done right and used in reasonable amounts it can be safe and a worthy mod. However, its not for me.
post Jan 19, 2006 - 11:57 AM
GMoney
Joined Jan 18, '06
From St.lucia
post Jan 19, 2006 - 12:07 PM
say nitrous please
NOS is a brand not the actual substance....
and the ONLY way i see usable on any swap is as an
NTERcooler....made by NX
post Jan 19, 2006 - 1:36 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
id squirt if i had the money to have my motor -Professionally- tuned for it.
i know plenty of people that have it and its mint. but.
i also know alot who now have holes in there blocks.
a 50shot isnt anything to worry about. if YOU want it. go for it.
you drive it, not us.
post Jan 19, 2006 - 2:03 PM
CilverSeliST205
Joined Nov 3, '05
From Chicago Suburbs
Believe it or not but if you put as much effort into setting up nitrous system on your car as you would into turboing n/a motor, then your only drawback is limited supply of N2O that cost $$$
People supporting their negative opinion about nitrous with horror stories of explosions, metdowns etc. obviously do not have much knowledge in automotive phisics.
Besides 50 shot on 3sgte could be the alternative way of reaching your hp goal, that could save you some expenses or labor
This post has been edited by CilverSeliST205: Jan 19, 2006 - 2:06 PM
QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback]
i dont drive fast, i just fly low
post Jan 19, 2006 - 2:19 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
i say if u know
-the differences between each application
-how to tune/install yourself
-what else to change so your motor doesn't blow/f-up
-how to maintain it
-how to remove it
-use it safely
i say go for it.
just list out a couple pros/cons first since everybody seems to knock it. find out why they dont like it.
post Jan 19, 2006 - 9:02 PM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
im considering the cryosystem or whatever its called my NX that sprays the N2o on the IC, im going to use it on a DSM sidemount as a way to hopefully help out with the effeciency of the small a-a IC. direct nitrous systems into the motor i have had experience with even wet systems not being consistant enough for me to reuse my system. blew up a 3000gt that way, it just doesnt spread evenly through the cylinders enough. a direct port system with a mild-pro tune would be a much better choice if you decide you want it.
my oppinion, take it or leave it
post Jan 19, 2006 - 9:23 PM
SHERMAN
Joined Dec 22, '05
From STL
The cryo2 system sprays carbon dioxide (CO2) on the intercooler to boosted air cooler.
I would go with nitrous express, people I know with It say it is the best system on the market today.
7a-fte in progress
still need a manifold, fuel pump, greddy e-manage, and oil lines / water lines
post Jan 19, 2006 - 10:01 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
too expensive for the refills
had a 100 shot on my car, needed to pull 4 degrees of timing out of the car so it wouldnt knock
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Jan 19, 2006 - 10:12 PM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
what motor and did you compensate for the nos with fuel?
also sorry about the name mixup i know the cryo systems spray co2 which if ingested by the motor youll loose power, i just couldnt think of the clever name NX has for their system.
post Jan 19, 2006 - 10:55 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
david, only do it if youre going with a direct port setup. as far as what brands are good... to me theyre all the same. its a bottle, some braided lines, solenoids. just make sure its direct port, purge-able, and not more than 50. i mean, its pretty much a brand new 3s u got there. dont really wanna **** it up. so as long as its setup right you'll be fine and just regular maintenance, making sure the lines are clear and str8, etc. my setup was pretty nice. i had the armor switch in the small panel on the bottom-left of the steering wheel for the fuses. then the cig lighter was chopped off in the back and i glued the purge button to the back of it so that when i pushed the cig lighter button in, it would purge. i used a lot of jbweld to make sure it stayed on there. worked like a charm. the bottle was behind my seat for easy access. the main line was ran from the bottle behind me into the carpet and under the door sill and behind that little kick panel by the door, behind the pedals and through a hole i drilled there where the main line, pressure gauge line, switch/button wires ran through. it purged out of the 2 sides of the hood. i used brass turbing for the purge lines and a t connector so it shoots out both sides. i recommend u only purge out of one place because the way i had it, it sprayed more out one side(drivers) than the other side of the hood cuz obviously, it took longer to get there. but i know thats mostly for sho. so i mean, to make it functional, really, u only need a short route and just let it out. on my setup, i didnt have a fuel solenoid and all, only a nitrous one so i put that about 6 inches from the throttle body on my cai and it worked fine. i had a 50 on mine and rarely used the 75 jet. but my engine has like 200 something on the odo and its running fine. turbo is going in soon. let me know when i can stop by the shop to check out the 3s. its done being built yet?
post Jan 19, 2006 - 11:24 PM
its a good thing for a quick joyride, but a slow car with a 50shot is still a slow car. after about 10-20joy rides, have and 2nd motor handy
post Jan 19, 2006 - 11:37 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(celicast3sgte @ Jan 19, 2006 - 7:12 PM) [snapback]381249[/snapback]
it was on my WRX
and it was a wet shot
still, when you run more than a 50 shot, you need to back off the timing.
post Jan 20, 2006 - 1:29 AM
Punch
Joined Jan 29, '04
gonna run a 50 shot direct port; hopefully with about 10 psi... I got a PRO putting it in...
JoKeRkId613 I'll give you a call as soon as i'm gonna put the motor in, and thanks for the heads up...
This post has been edited by Punch: Jan 20, 2006 - 5:03 AM
post Jan 20, 2006 - 1:47 AM
QUOTE(Punch @ Jan 20, 2006 - 1:29 AM) [snapback]381368[/snapback]
gom run a 50 shot direct port hopefully with about 10 psi... I got a PRO putting it in...
famous last words... lol
post Jan 20, 2006 - 1:26 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(lagos @ Jan 19, 2006 - 10:47 PM) [snapback]381378[/snapback]
nitrous is easy to install
tuning for it and using it in moderation is the hard part.
post Jan 21, 2006 - 12:47 AM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
QUOTE(97sccelica @ Jan 20, 2006 - 11:26 AM) [snapback]381527[/snapback]
^very true. easy and pretty common-sense to install. i didnt tune mine. i guess im lucky that p.o.s didnt blow up since everyone makes it seem like nitrous is the devil.
Lo-Fi Version Time is now: September 2nd, 2026 - 6:55 AM
