> Air Intake!
post Jan 20, 2006 - 11:03 PM
xpokeme
Joined Jan 18, '06
i juz installed an air intake on my 97 celica st.....it fits and all but i have one problem, i dunt know where to connect the blue hose....where does it go? i cant find a hole to stick it in lol....someone please HELP!!
post Jan 20, 2006 - 11:12 PM
zachattack15
Joined Aug 16, '04
From Baton Rouge, LA
Make a hole
post Jan 21, 2006 - 1:22 AM
ZacMan1987
Joined Jan 6, '06
Um. Which hose? On mine, I was forced to leave a hose loose. The "vital" hose is the crank case vent, which needs to go from the crank case to the intake pipe. I think the cleaner option is to install a catch tank. However, for the time being, I've just got a loose hose floating around in there.
Here's what my 99 GT had.
On the stock intake pipe, there was the temp sensor, the tube coming from the crank case, and one going from the intake pipe down to somewhere, which I didn't bother to figure out. That's for tomorrow.
As far as I know, the important thing to do is reinsert the temp sensor, and clamp the tube coming from the crank case to the intake pipe.
This post has been edited by ZacMan1987: Jan 21, 2006 - 1:27 AM
post Jan 21, 2006 - 4:15 AM
Hanyo
Joined Aug 16, '03
From Bay area
if your lazy, get a cheap breather filter from kragen.
post Jan 21, 2006 - 11:08 PM
Jaws4God
Joined Mar 27, '04
thats how i set mine up...
~Daniel
post Jan 22, 2006 - 12:03 AM
ZacMan1987
Joined Jan 6, '06
P.S. I'm assuming the rationale for running the CAI pipe outside like so many seem to do would be it keeps the pipe cooler? I just ran mine straight forward to the left of the battery, then down below the battery, but it does pick up a lot of heat from the exhaust manifold.
post Jan 22, 2006 - 12:47 AM
Alchemist_57
Joined Jun 12, '05
From Box Springs, GA
Yup, that's the reason. The air inside the fender is cooler than in the engine compartment. That's why the stock "piping" is setup like that.
~bob
Lo-Fi Version Time is now: August 23rd, 2026 - 2:22 AM
