> plumbing for turbo (w/pics), is it to small?
post Jan 21, 2006 - 7:57 PM
southwest2118
Joined Jan 13, '06
Ok guys i went to pepboys and bought this to weld to my oil pan
what do you think? Its made for a 3/4" hose its 1-3/4' long and
the thread is 1/2" NPT. is it too small?
Then i went to Ace hardware and bought 2 TEEs a nipple and plug and some thread seal tape. they had no crosses. but its all 1/8" Npt so what i'ma do is buy a male 1/8" BSPT to male 1/8" NPT and a male NPT to female BSPT. and everything should work out.
user posted imageuser posted image
This post has been edited by southwest2118: Jan 22, 2006 - 4:43 AM
post Jan 26, 2006 - 12:45 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
i didn't even bother with the bspt adapter i took a 1/8" npt and it screwed right in. no problems with leaking at all.
This post has been edited by rjbibeau: Jan 26, 2006 - 12:46 PM
post Jan 27, 2006 - 1:03 AM
southwest2118
Joined Jan 13, '06
the other day i spent f*ckin 25$ for one
male bs to male npt and male npt to female bspt.
the female bs to male npt cost me 16$ WTF
post Jan 27, 2006 - 8:18 AM
why all the diffrent fittings??
just so you know, brass is about the worst thing you can use for those types of application, it is very weak and WILL crack.
if all that stuff is what i think it is (turbo oil feed) then you need to take all those back where you got them from, and get this:
http://tunertoys.zoovy.com/product/OTODK
its got the proper thread pitch for the head and allows you to keep your stock pressure switch.
the return needs to be 3/4" ID
post Jan 30, 2006 - 2:31 AM
southwest2118
Joined Jan 13, '06
too late buddy
post Jan 30, 2006 - 2:38 AM
celicaGT96
Joined Aug 14, '05
From Corpus Christi Tx
who cares if its too late.
so, you wasted money, you might as well just do it right the first time instead of using all these different fittings that can be avoided, plus like manny said, brass is not the best for those types of applications
post Jan 30, 2006 - 7:38 AM
too late buddy
remember that statement when one of those crappy fittings crack, drain all your engine oil in a matter of seconds, and blow your motor to a bunch of nice sized paper weights
post Jan 31, 2006 - 12:57 AM
southwest2118
Joined Jan 13, '06
the t fittings are pretty thick and the adapters to bsp are stainless steel maybe the nipple will break but i put everything together and tryed to break it with my hand ....you think the temp will be a big factor? **** ...where other then the INTERNET can i get a cross? 1/8 npt female all around? steel? i would have bought that adapter that presure2 was talking about but f*ck it. just get the cross
post Feb 3, 2006 - 3:02 AM
southwest2118
Joined Jan 13, '06
QUOTE(southwest2118 @ Jan 31, 2006 - 12:57 AM) [snapback]386838[/snapback]
oh ya the temp and vibration will be a factor.....did you try pepboys? hardware store?....somebody else asked this question i can't remeber who? kindasad.gif
last week got oil pan welded.
here it is.
Lo-Fi Version Time is now: August 11th, 2026 - 10:10 AM
