> after swap, not turning over ?!!?!?!, advise
post Jan 23, 2006 - 12:21 AM
here is the situation...a 94 5s went into a 96. The 96 harness was used and everything matched up except a few things (they were then swapped over from the 96 motor to the 94, i.e. distributer, OBDII, ect. ). Now after everything is all hooked up and put together, it doesn't start up. It cranks, the starter is good, but no vroom.
anything that I should check for specifically ?
any ideas ?
wtf ?
thanks
- Batman722   after swap, not turning over ?!!?!?!   Jan 23, 2006 - 12:21 AM
- - Dr_Tweak   Are you getting spark? Is the fuel pump running? D...   Jan 23, 2006 - 12:22 AM
- - Batman722   the problem is I am not at the engine to find out,...   Jan 23, 2006 - 12:36 AM
- - Dr_Tweak   Well, first off, "turn over" = cranking,...   Jan 23, 2006 - 12:40 AM
- - Batman722   you are correct, turning over, yes, starting, no. ...   Jan 23, 2006 - 12:43 AM
- - Dr_Tweak   Yeap, that's probably his problem right there.   Jan 23, 2006 - 1:07 AM
- - presure2   he prolly forgot somthing dustin, did he tell you ...   Jan 23, 2006 - 9:16 AM
- - Batman722   he swaped the cover and his dad did the timing bel...   Jan 23, 2006 - 11:13 AM
- - Agent21   There are supposidly some differences between cali...   Jan 23, 2006 - 9:43 PM
- - nightryder   ok guys, ill step forward, its my car. alright......   Jan 24, 2006 - 12:17 PM
- - lagos   QUOTE(nightryder @ Jan 24, 2006 - 12...   Jan 24, 2006 - 1:19 PM
- - nightryder   OK i have an update and an apology for my last pos...   Jan 24, 2006 - 1:55 PM
- - Sr_Ric   i know on some cars if your using diffrent wiring ...   Jan 24, 2006 - 3:38 PM
- - lagos   QUOTE(nightryder @ Jan 24, 2006 - 1...   Jan 24, 2006 - 4:12 PM
- - nightryder   Ive been doing some trouble shooting and i think i...   Jan 24, 2006 - 6:23 PM
- - Agent21   Take a multimeter on the positive pole and the lit...   Jan 24, 2006 - 7:33 PM
|- - nightryder   QUOTE(Agent21 @ Jan 24, 2006 - 7:33 ...   Jan 25, 2006 - 9:22 AM
- - Agent21   I only know this because mine blew out of no where...   Jan 25, 2006 - 3:26 PM
- - rjbibeau   i now too have the same prob as doggy. i swapped f...   Jan 27, 2006 - 2:42 PM
- - Agent21   Could be the ignition control module as well. It i...   Jan 27, 2006 - 7:43 PM
- - Batman722   The problem is most likely getting corrected right...   Jan 27, 2006 - 11:35 PM
|- - nightryder   QUOTE(Batman722 @ Jan 27, 2006 - 11...   Jan 30, 2006 - 12:22 AM
- - rjbibeau   i'll check and see. i checked all fuses and al...   Jan 28, 2006 - 12:39 AM
- - Agent21   Well the ugly way is to buy one with a return poli...   Jan 28, 2006 - 3:16 PM
- - nightryder   ok a break in the case! I had a buddy come do...   Jan 30, 2006 - 12:19 AM
- - lagos   QUOTE(nightryder @ Jan 30, 2006 - 12...   Jan 30, 2006 - 12:24 AM
|- - nightryder   QUOTE(lagos @ Jan 30, 2006 - 12:24 A...   Jan 30, 2006 - 12:28 AM
- - lagos   QUOTE(nightryder @ Jan 30, 2006 - 12...   Jan 30, 2006 - 1:08 AM
|- - nightryder   QUOTE(lagos @ Jan 30, 2006 - 1:08 AM...   Jan 30, 2006 - 1:16 AM
- - Batman722   Nate, I am free tomorrow after 7ish...give me a ca...   Jan 30, 2006 - 1:55 AM
- - Agent21   "my wonderful "wrangler enthusiast...   Jan 30, 2006 - 2:25 PM
|- - nightryder   QUOTE(Agent21 @ Jan 30, 2006 - 2:25 ...   Jan 30, 2006 - 7:01 PM
- - nightryder   And the clouds opened up and god said "Let it...   Feb 2, 2006 - 6:58 PM
- - rjbibeau   there's a ground on the back of the block?.......   Feb 3, 2006 - 10:35 AM
- - presure2   it attaches to the back of the intake manifold.   Feb 3, 2006 - 10:36 AM
- - rjbibeau   sweet deal maybe that's my problem. where does...   Feb 3, 2006 - 10:56 AM
|- - nightryder   QUOTE(rjbibeau @ Feb 3, 2006 - 10:56...   Feb 3, 2006 - 6:15 PM
- - Batman722   Glad to hear the beast is running again Nate g...   Feb 4, 2006 - 1:38 AM
- - nightryder   it idles at like 2000 rpms now, its a lil high... ...   Feb 4, 2006 - 6:00 PM
- - rjbibeau   good news guys my engine is alive. it runs smooth....   Feb 4, 2006 - 6:44 PM
- - Batman722   Just to let you all know, Nate's (nightryder) ...   Feb 14, 2006 - 12:08 AM
- - Dr_Tweak   He didn't buy a clip?   Feb 14, 2006 - 12:19 AM
- - lagos   QUOTE(Dr_Tweak @ Feb 14, 2006 - 12:1...   Feb 14, 2006 - 12:25 AM
- - nightryder   QUOTE(lagos @ Feb 14, 2006 - 12:25 A...   Feb 14, 2006 - 7:33 AM
Lo-Fi Version Time is now: August 23rd, 2026 - 5:48 PM
