Jan 23, 2006 - 4:17 PM
Enthusiast ![]() ![]() Joined Jun 27, '04 From ohio Currently Offline Reputation: 7 (100%) |
I have a 3rd gen st205 engine. The harness I recieved was hacked up, upon reciving my new one I have a plug that is labled airbox what sensor does this go to? thanks lance
Jan 23, 2006 - 4:25 PM
![]() Enthusiast ![]() ![]() Joined Jan 22, '06 From Melbourne, Australia Currently Offline Reputation: 0 (0%) |
not 100% sure - but possibly the air temp sensor on the airbox?
-------------------- www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS 15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2 |
Jan 23, 2006 - 4:51 PM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
Photograph?
-------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Jan 23, 2006 - 9:04 PM
QUOTE(GT4WRC @ Jan 23, 2006 - 9:51 PM) [snapback]382859[/snapback] Photograph? I do not have easy access to a digital camera. I purchased just the engine and am now sourcing parts it is a two wire conector lables air box. There is not an afm so it is probably an air temp sensor just wanted to know if anyone knew off the top of their head thanks lance |
Jan 23, 2006 - 11:43 PM
I can take a better pic if required but...
Look just above the filter, between the red cable and the loom harness and you'll see a black sensor. This plugs into the standard airbox. Is this teh one you mean? Gray -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Jan 24, 2006 - 11:08 AM
QUOTE(GT4WRC @ Jan 24, 2006 - 4:43 AM) [snapback]383157[/snapback] I can take a better pic if required but... Look just above the filter, between the red cable and the loom harness and you'll see a black sensor. This plugs into the standard airbox. Is this teh one you mean? Gray Yes that looks like the plug I am talking about; what is the sensor for and what is it called? I have a few other plugs that need a home. If I can track down a digital camera I will take pics. I also need to know where some other parts go, ex) charcol canister, coil, and ignitor, various vaccum lines. Thank you for your help Lance |
Jan 25, 2006 - 7:48 AM
its called IAS, or Intake Air Sensor. it detects teh temp of the air going into your turbo, and uses that value to determine which compansation map the ecu uses.
Jan 25, 2006 - 6:00 PM
QUOTE(presure2 @ Jan 25, 2006 - 12:48 PM) [snapback]383946[/snapback] its called IAS, or Intake Air Sensor. it detects teh temp of the air going into your turbo, and uses that value to determine which compansation map the ecu uses. This may be a stupid question but is this sensor only found on turbo models? Or is this only found on the 3rd gen engine? thanks lance |
Jan 25, 2006 - 6:32 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
QUOTE(lantz2121 @ Jan 25, 2006 - 3:00 PM) [snapback]384252[/snapback] QUOTE(presure2 @ Jan 25, 2006 - 12:48 PM) [snapback]383946[/snapback] its called IAS, or Intake Air Sensor. it detects teh temp of the air going into your turbo, and uses that value to determine which compansation map the ecu uses. This may be a stupid question but is this sensor only found on turbo models? Or is this only found on the 3rd gen engine? thanks lance There is an intake temp sensor on most cars. |
Jan 25, 2006 - 8:35 PM
QUOTE(CheesyLobster @ Jan 25, 2006 - 11:32 PM) [snapback]384269[/snapback] QUOTE(lantz2121 @ Jan 25, 2006 - 3:00 PM) [snapback]384252[/snapback] QUOTE(presure2 @ Jan 25, 2006 - 12:48 PM) [snapback]383946[/snapback] its called IAS, or Intake Air Sensor. it detects teh temp of the air going into your turbo, and uses that value to determine which compansation map the ecu uses. This may be a stupid question but is this sensor only found on turbo models? Or is this only found on the 3rd gen engine? thanks lance There is an intake temp sensor on most cars. I want to know if I have to locate a st205 one of if I can find one from another generation. Any usdm cars have the one that is needed? thanks lance |
Jan 25, 2006 - 8:40 PM
IATs are found on all cars but in that particular form... it's on MAP sensored cars...
And... an IAT is an IAT... I don't think there is a lot of variation between them... so long as you match up the wires. This post has been edited by Kwanza26: Jan 25, 2006 - 8:41 PM -------------------- "It's ok to be naked girl... I'm an artist!"
Feb 5, 2006 - 11:26 PM
Enthusiast ![]() ![]() ![]() Joined Dec 11, '04 From USA Currently Offline Reputation: 12 (83%) |
QUOTE(lantz2121 @ Jan 23, 2006 - 4:17 PM) [snapback]382823[/snapback] I have a 3rd gen st205 engine. The harness I recieved was hacked up, upon reciving my new one I have a plug that is labled airbox what sensor does this go to? thanks lance hey, you still have that jacked up harness ? i have real st205 down here in cincy might want for a project d- -------------------- Old guy with the toys
95 ST205 WRC (the real deal) 94 MR2 HARDTOP Supercharged 2GR/6SPD 22 owned ![]() |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 3:11 AM |
