> 3s-ge tunability
post Jan 28, 2006 - 2:06 AM
lumbercis
Joined Jan 28, '06
From Washington, DC
Hi all,
I just have a few general questions about the 3rd gen 3sge (non-beams) that came in the JDM celicas.
1. How "tunable" is this engine? IOW, how does it respond to aftermarket modification? What kind of hp numbers have been seen with this engine?
2. How much aftermarket support is there for this engine?
3. What is an average cost for this swap? Is it much more expensive for the BEAMS?
4. How would you compare this engine to something like the b18c1 (Integra GSR engine)?
Thanks for your help.
J.
post Jan 28, 2006 - 5:53 AM
Dee-No
Joined Dec 23, '04
From Switzerland
1. not very tunable. There are some modifications but they won't bring you a lot of HP. I think the absolute max would be about 195HP (full exhaust system, CAI, air filter-mushroom)
2. Support shouldn't be a problem (at least here in Europe)
post Jan 28, 2006 - 11:19 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
Check maikl's profile. He's bulding a 3sge. His is a Beams, but I think most parts are at least similar. I think you can really build these things. They use these motors a lot over seas. And with the upgraded verson in the new Lexus IS300 (I think), there will be parts for this thing. My advice, is just go with the Beams, because it will have more parts for it. But I know I would personal go with the regular 3sge, and just go from there. I can't name anything you can't get for it. You can build the bottem end using 3sgte parts. You can get cams made from Webcamshafts.com. They'll make springs and what not too. I don't think finding parts that will work on this motor will be hard, and I think it could hit 300hp or more. That's pretty much none streetable, but I bet you could do 250hp streetable.
Live Free, Be Happy
post Jan 28, 2006 - 5:24 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(Dee-No @ Jan 28, 2006 - 10:53 AM) [snapback]385643[/snapback]
If that's what you consider tuning... well... no... then it's about as tuneable as any other engine. Bolt-ons isn't tuning btw... they're merely bolt-ons. There isn't much "tuning" involved.
The 3SGE is a great platform to start off on with n/a tuning. By tuning I mean, camshafts, pistons, fuel/ignition tuning, intake tuning, etc. All engines are as tuneable as the amount of money you're willing to throw at it. Comparatively speaking, the 3SGE (2nd gen+) can outperform the B18C1 simply because it's a bigger engine. The B18C will always have some sort of top-end advantage over the 3SGE... but the 3SGE can delivery a much broader and useable powerband compared to the B18C1.
Lo-Fi Version Time is now: September 2nd, 2026 - 4:18 AM
