Jan 28, 2006 - 5:02 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 31, '02 From Virginia Currently Offline Reputation: 4 (100%) |
Where is the best place to put the 2 jack stands when jacking up the rear? I jacked up the car the other day for the first time to paint the calipers, and placed them right near the jacking points, but the frame seems so thin in the rear and the car was only sitting on the inside of the "U" shape part of the stand "arm" (as the U shape faces the wheel wells), so it seemed like only less than 1 inch on each side of the car was sitting on the stands. I guess the frame is not exactly parallel to the ground, b/c I know the jack stands are okay. Anyways, just wanted to see if you guys do it differently? Thanks!
Celicav Jack Stands in Rear Jan 28, 2006 - 5:02 AM
Dr_Tweak I usually do it the same you did. Nothing to worry... Jan 28, 2006 - 6:21 AM
presure2 yup, i do the same as yall Jan 28, 2006 - 6:38 AM
blu94gt don't worry, those places on the frame are des... Jan 28, 2006 - 11:51 AM
creis rear jack points, you mean the edge of the car rig... Jan 30, 2006 - 12:46 AM
macavely QUOTE(creis @ Jan 30, 2006 - 12:46 A... Jan 30, 2006 - 1:02 AM
Celicav QUOTE(creis @ Jan 29, 2006 - 10:46 P... Jan 30, 2006 - 11:38 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 29th, 2026 - 7:30 PM |
