> somethigns rong 5sfte, blaaa craig needs help
post Jan 30, 2006 - 3:28 PM
urbandork
Joined Jul 16, '04
From Los Angeles
When im runing 7 psi everything is fine. but as soon as get up to like 10 11 psi my eninge gets all wacked out.
at 10 11 psi it makes a really bad sputtering sound, jerks around and loses power. Is this the 2 bar map sensor doing that boost cut, is it cutting fuel?
i have an mbc on it because before the turbo was only doing like 4 psi. I had to take the cap off the nipple on the second pipe of the waste gate to get it to do 7 psi. Now i have it caped off with the mbc set at 7 and have problems with it when i get up int he 10 psi range.
This post has been edited by urbandork: Jan 30, 2006 - 3:32 PM
- urbandork   somethigns rong 5sfte   Jan 30, 2006 - 3:28 PM
- - x_itchy_b_x   are u running the proper Gap on the plugs?   Jan 30, 2006 - 3:37 PM
- - urbandork   yup .30 right? thats what i set it at when i put t...   Jan 30, 2006 - 3:45 PM
- - lagos   sounds like detonation what injectors and piggy b...   Jan 30, 2006 - 3:49 PM
- - urbandork   safc2 and ngk i forget the number but they are cop...   Jan 30, 2006 - 4:00 PM
- - lagos   what injectors are u running?...not spark plugs...   Jan 30, 2006 - 4:04 PM
- - urbandork   im running 42 pound bosch injectors so about 441cc...   Jan 30, 2006 - 5:03 PM
- - NuclearHappineS   if you hit fuel cut you should see the Check engin...   Jan 30, 2006 - 5:18 PM
- - urbandork   ngk plugs bkr7es11 255 lph fuel pump I think my ...   Jan 30, 2006 - 6:21 PM
- - presure2   urban, is it RPM dependant or boost dependant? wha...   Jan 30, 2006 - 7:27 PM
- - x_itchy_b_x   u have u btm at 3?! u only need to set it at ....   Jan 30, 2006 - 7:46 PM
|- - urbandork   QUOTE(x_itchy_b_x @ Jan 31, 2006 - 12...   Jan 30, 2006 - 8:39 PM
- - NuclearHappineS   if the CEL is coming on it's fuel cut for sure...   Jan 31, 2006 - 3:59 AM
|- - Dr_Tweak   QUOTE(NuclearHappineS @ Jan 31, 2006 - 8...   Jan 31, 2006 - 4:25 AM
- - presure2   you shouldnt be hitting fuel cut @ 10-11psi, ive h...   Jan 31, 2006 - 9:34 AM
- - urbandork   QUOTE(presure2 @ Jan 31, 2006 - 2:34...   Jan 31, 2006 - 11:43 AM
- - dlx742   it sound ur leaning out, ive had this happen befor...   Feb 4, 2006 - 12:12 AM
- - presure2   craig, you said on AIM you had to ADD fuel up top?...   Feb 4, 2006 - 8:51 AM
- - urbandork   manny. although im adding that much fuel most of t...   Feb 4, 2006 - 12:28 PM
- - presure2   im not concerned with what your gauge reads. if yo...   Feb 4, 2006 - 2:49 PM
- - rjbibeau   sounds like a fuel filter issue. your car is a 95 ...   Feb 5, 2006 - 2:13 PM
|- - urbandork   well i got the new fuel filter in and also changed...   Feb 10, 2006 - 5:38 PM
- - presure2   yes, it will. that should be in your intercooler p...   Feb 10, 2006 - 6:53 PM
- - CheesyLobster   QUOTE(presure2 @ Feb 10, 2006 - 3:53...   Feb 10, 2006 - 8:08 PM
- - urbandork   QUOTE(CheesyLobster @ Feb 11, 2006 - 1...   Feb 10, 2006 - 11:43 PM
Lo-Fi Version Time is now: September 3rd, 2026 - 1:29 AM
