> post swap problems, high idling
post Feb 2, 2006 - 6:52 PM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
i swapped my 5sfe for a new one and after the swap, now the idles are way off , around 2000rpms. do i need to adjust the idle? how would i go about doing so? anyone? anyone?
This post has been edited by nightryder: Feb 3, 2006 - 6:20 PM
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
- nightryder   post swap problems   Feb 2, 2006 - 6:52 PM
- - Dr_Tweak   Sounds like a vacuum leak most likely. -Doc   Feb 19, 2006 - 11:45 PM
- - lagos   and check your timing, sometimes that can get too ...   Feb 19, 2006 - 11:47 PM
- - Batman722   problem solved   Feb 19, 2006 - 11:48 PM
- - Dr_Tweak   Cause?   Feb 20, 2006 - 4:43 AM
- - nightryder   there was a cracked vacuum line like you said doc,...   Feb 21, 2006 - 8:01 PM
- - Dr_Tweak   I'm glad it was a simple fix for ya -Doc   Feb 22, 2006 - 12:45 AM
Lo-Fi Version Time is now: August 21st, 2026 - 11:43 PM
