> 3SGTE Third ECU Plug, 22pin Connector
post Feb 3, 2006 - 5:20 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Just thought I'd let everyone know that the 22pin ECU connector from the either the ST or GT with automatic transmissions will work for your 3SGTE's third ECU plug. The connector will have to be repinned and some of the wire colors will not match, but it does plug directly into the 3SGTE ECU. I hope this information will help anyone in the future that is looking for this particular part to their swap.
Also, I'd assume any automatic 5SFE or 7AFE powered car from about 94-99 will probably have the same plug. Camry's, Corrolas and MR2s come to mind but I'm sure there are more.
- WannabeGT4   3SGTE Third ECU Plug   Feb 3, 2006 - 5:20 PM
- - Dr_Tweak   Any 22-pin Toyota plug will work, FYI. -Doc   Feb 3, 2006 - 8:30 PM
|- - WannabeGT4   QUOTE(Dr_Tweak @ Feb 3, 2006 - 7:30 ...   Feb 3, 2006 - 11:26 PM
- - lagos   good to know, because this was alway an issue for ...   Feb 4, 2006 - 4:13 PM
|- - Dr_Tweak   QUOTE(lagos @ Feb 4, 2006 - 9:13 PM)...   Feb 4, 2006 - 11:41 PM
- - CelicaSTX02   man, lagos is always yelling at me for not buying ...   May 11, 2006 - 12:30 PM
- - Doge   My 3rd ecu plugged directly into the 185 ECU. Onl...   May 11, 2006 - 2:52 PM
- - jcbass7   QUOTE(lagos @ Feb 4, 2006 - 4:13 PM)...   May 11, 2006 - 3:17 PM
- - WannabeGT4   You've already got one since you're auto. ...   May 11, 2006 - 3:19 PM
|- - jcbass7   QUOTE(WannabeGT4 @ May 11, 2006 - 3...   May 11, 2006 - 3:45 PM
- - 2slow2nervous   i have a question is there a how to: on the repinn...   Dec 19, 2006 - 9:02 AM
- - lagos   QUOTE(2slow2nervous @ Dec 19, 2006 - 9...   Dec 19, 2006 - 4:10 PM
- - playr158   actually thats just the cheap way out... the best...   Dec 19, 2006 - 4:15 PM
- - lagos   QUOTE(playr158 @ Dec 19, 2006 - 4:15...   Dec 19, 2006 - 4:53 PM
|- - 2slow2nervous   alrite thank u guys....now if i sent the harness t...   Dec 19, 2006 - 5:04 PM
- - lagos   QUOTE(2slow2nervous @ Dec 19, 2006 - 5...   Dec 19, 2006 - 5:06 PM
|- - 2slow2nervous   now see the shop i had my car chopped my 5sfe harn...   Dec 19, 2006 - 5:14 PM
- - playr158   installing a harness is pretty easy, but defenitly...   Dec 19, 2006 - 5:14 PM
- - Batman722   good solution. Installing the harness on the engin...   Dec 19, 2006 - 5:16 PM
|- - 2slow2nervous   i am working on that i need this car on the road...   Dec 19, 2006 - 5:22 PM
- - Batman722   the ECU is under the climate control unit in the c...   Dec 19, 2006 - 5:30 PM
|- - 2slow2nervous   ok cool. and the harness once i get back will lay ...   Dec 19, 2006 - 5:38 PM
- - playr158   ECU is located inside your dash directly below you...   Dec 19, 2006 - 6:32 PM
- - JaxMadine   But I have the same problem and have already hacke...   Dec 19, 2006 - 8:04 PM
|- - Dr_Tweak   QUOTE(JaxMadine @ Dec 20, 2006 - 1:0...   Dec 27, 2006 - 8:53 AM
|- - jcbass7   QUOTE(Dr_Tweak @ Dec 27, 2006 - 8:53...   Dec 27, 2006 - 9:50 AM
- - JaxMadine   i dun wanna send the harness out, i just put it ba...   Jan 11, 2007 - 5:53 PM
Lo-Fi Version Time is now: August 28th, 2026 - 5:17 AM
