Feb 5, 2006 - 5:14 PM
Enthusiast ![]() Joined Apr 21, '04 Currently Offline Reputation: 0 (0%) |
edit
This post has been edited by sickman89: Jun 26, 2008 - 6:48 PM |
Feb 5, 2006 - 5:22 PM
QUOTE(sickman89 @ Feb 5, 2006 - 5:14 PM) [snapback]389274[/snapback] where can I purchase an intercooler kit or and an front mount intercooler piping kit for the st205 in the U.S. I am also thinking that I can make one from the st185 work. Any ideas? you just need a bunch of bends and an intercooler, no one really makes a specific kit for our cars... but if you have an st205, then i wouldnt bother with a fmic. the top mount water to air is a VERY good cooler -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 8, 2006 - 9:58 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jun 21, '03 From Pennsylvania Currently Offline Reputation: 3 (100%) |
I make ic pipe kits for our cars, and there are other people out there that make ic piping too (but i agree...very small amount of people make a bolt on kit).... ive done 4 or 5 kits for people on this board. I think the main thing is that people just try to save cash and run 20 couplers all over the place rather than spending the extra bucks getting a bolt on kit with cool welds using less couplers. It is all about the looks when it comes down to it cause having extra couplers really cant hurt the air flow too much? On the other hand....every little bit helps!!!
DG -------------------- ![]() |
Feb 8, 2006 - 10:21 PM
QUOTE(DG_Performance @ Feb 8, 2006 - 8:58 PM) [snapback]391021[/snapback] It is all about the looks when it comes down to it cause having extra couplers really cant hurt the air flow too much? DG Except for the extra joints to develop leaks. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Feb 9, 2006 - 10:09 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
Yeah but I actually think all the couplers looks sweet if done right. Just my opinion though.
Feb 9, 2006 - 10:20 AM
yeah but it sucks when one blows off on the highway and scares the crap out of you.
(couplers) -------------------- |
Feb 9, 2006 - 12:16 PM
QUOTE(x_itchy_b_x @ Feb 9, 2006 - 8:20 AM) [snapback]391232[/snapback] yeah but it sucks when one blows off on the highway and scares the crap out of you. (couplers) very true...i totally forgot about that. I had that happen to me 2 times.... and it is always the coupler that is impossible to get to, or the one next to something very hot! -------------------- ![]() |
Feb 9, 2006 - 3:50 PM
that only happens on those cheap home depo couplers that were never ment to support the weight of steal IC piping. i had my cheapo ones blow off on me too, right next to a hot downpipe (why does it always happen on the highway?).
now im using the t-bolt clamps and NEVER had any issues with them, in almost over a year of using them. i had some of my piping welded (the stuff under the car) , but i perfer having the whole thing in easy to take apart sections. that way its easy to take apart, when you need to do some work on your car . if you get the correct clamps from day one, youll never have a problem with them This post has been edited by lagos: Feb 9, 2006 - 5:40 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 9, 2006 - 9:38 PM
![]() Enthusiast ![]() ![]() Joined Jan 22, '06 From Melbourne, Australia Currently Offline Reputation: 0 (0%) |
Problem with the ST205 WTA cooler... true that the coolant doesn't get heat soak as easily, but once it's soaked, it stays soaked for ages.
-------------------- www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS 15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2 |
Feb 10, 2006 - 7:50 AM
QUOTE(lagos @ Feb 9, 2006 - 3:50 PM) [snapback]391367[/snapback] that only happens on those cheap home depo couplers that were never ment to support the weight of steal IC piping. i had my cheapo ones blow off on me too, right next to a hot downpipe (why does it always happen on the highway?). now im using the t-bolt clamps and NEVER had any issues with them, in almost over a year of using them. i had some of my piping welded (the stuff under the car) , but i perfer having the whole thing in easy to take apart sections. that way its easy to take apart, when you need to do some work on your car . if you get the correct clamps from day one, youll never have a problem with them i agree with art totally. if you use GOOD clamps and couplers, you can have 0 problems. ive never had a coupler blow loose, or anything of the sort. then again, i started from day one with good hightempsilicone couplers, and T-bolt clamps. when my 3s goes in, ill be switching from aluminized steel to aluminum.. some if it will be welded, but it will still need a few couplers, cause you need to be able to get it in and out in sections, like art said. -------------------- Former Team 5SFTE pro member ;)
Feb 10, 2006 - 5:41 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 30, '03 From Cyprus Currently Offline Reputation: 0 (0%) |
QUOTE(sickman89 @ Feb 6, 2006 - 12:14 AM) [snapback]389274[/snapback] where can I purchase an intercooler kit or and an front mount intercooler piping kit for the st205 in the U.S. I am also thinking that I can make one from the st185 work. Any ideas? Few garage's in Japan are making Intercooler kit for ST205(for standard CT20B turbo,i mean piping and core) but it very expensive!!!If you are planning for some serious power then you should go for custom piping,dont forget to short the chargecooler water level wires for the check signal |
Feb 10, 2006 - 6:25 PM
Magic, do you have any photos/links/details about these kits?? very interested.
Feb 10, 2006 - 7:11 PM
tangcla have a look at Brashboy (www.brashboy.net) they were selling one for the ST205 @ 218.000Yen!!!!!I am not sure about the core,it looks like a Blitz to me.
Jspeed (http://cs-marche.com) has one for the ST205 @ 158.000Yen!!!Its cheaper,follow the link below to the section with the Celica parts: Jspeed You can find also garage's that can make to you one-off intercooler kits for ST205 like Signal or Top Fuel but you have to order it and i dont know how much they charge,you have to contact with them. I hope this will help you If you want my opinion go for custom piping and look after for a Trust or HKS core |
Feb 11, 2006 - 11:43 AM
ouch... I think I might even stick with the top mount WTA unit and go water injection into the intake manifold... seems to work better that way! They say it lowers intake temps by up to 24 degrees...
Feb 11, 2006 - 12:51 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 1, '03 From WV Currently Offline Reputation: 2 (100%) |
My dad has to use a welded peice on his truck. He's running around 30psi though. He's always told me that it's best to have a solid piped from the charged side to the intake. I don't think it would matter for the people running 5-10psi. What would be the limit though?
Feb 13, 2006 - 9:45 AM
There is not set number where couplers just start to blow off... it depends on a lot of conditions and will be different for each person. I have blown off couplers on my first 5sfte setup at 6psi a bunch of times so it can happen under 10psi. The easiest way to know for sure when you hit your own limit is when you blow off couplers all the time. If your find yourself out on the side of the road adjusting couplers more and more often you should start looking into welding some of them together. That is how i started making ic piping... I was uping the boost and around 9psi i was blowing off couplers every time i would full throttle it! I was not using t clamps at that time but i just got sick of being under the car on the side of highways! Not Safe... haha.
dg -------------------- ![]() |
Feb 13, 2006 - 9:49 AM
QUOTE I was uping the boost and around 9psi i was blowing off couplers every time i would full throttle it! I was not using t clamps at that time but i just got sick of being under the car on the side of highways! Not Safe... haha. dg crappy clamps will do it every time...lol just for refrence, hyde runs 22+ psi with silicone couplers, and constant tension clamps. no problems. ive hit 15psi @ the track, and run 10+psi daily, and have NEVER had a hose pop off. its all about using the proper clamps and couplers, and getting them good and tight. This post has been edited by presure2: Feb 13, 2006 - 9:56 AM -------------------- Former Team 5SFTE pro member ;)
Feb 13, 2006 - 7:40 PM
yeah, you cant compare the hardware store junk to t-bolts. sure its good to get really hard to reach stuff welded, but for everythihng else, if you get tbolts you will NEVER have one blow off.
Feb 15, 2006 - 7:34 AM
I would not say crappy clamps will do it every time...lol
and hyde runs 22+ psi with silicone couplers, and constant tension clamps. no problems. I would bet hyde has the extra lips welded on the ends of his piping to help avoid a blow off This post has been edited by DG_Performance: Feb 15, 2006 - 7:35 AM -------------------- ![]() |
Feb 15, 2006 - 2:51 PM
QUOTE(DG_Performance @ Feb 15, 2006 - 7:34 AM) [snapback]394229[/snapback] I would not say crappy clamps will do it every time...lol and hyde runs 22+ psi with silicone couplers, and constant tension clamps. no problems. I would bet hyde has the extra lips welded on the ends of his piping to help avoid a blow off actually, no, he dont, his whole intercooler setup was bought off ebay. just a decent core and some bends, nothing out of the ordinary, dave. -------------------- Former Team 5SFTE pro member ;)
| Lo-Fi Version | Time is now: June 23rd, 2026 - 7:23 AM |
