> Wierd Problem, help...
post Feb 5, 2006 - 11:40 PM
d3monc3lica
Joined Aug 19, '04
From Maine
Okay....So i was driving an extended distance andI go to shift all of a sudden I cant get into gear....... The only time I can put it into gear is when the car is shut off, OR if I let the car sit for a while it will work but then after warming up it does the same thing......any ideas?
post Feb 6, 2006 - 12:08 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Sounds like your clutch is shot. If you force it into gear with the clutch in will it gring and go in? Or it just won't go in at all?
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Feb 6, 2006 - 12:32 AM
d3monc3lica
Joined Aug 19, '04
From Maine
It will not go in at all, the clutch was just replaced last year and then was fixed again by the same people a couple months later because they screwed up, i seriously think they did something...I know how to drive a standard........GRRR I just figured it could be the throwout bearing or something.....but hell if I know, either way im so pissed off at the garage that did it because I know it's their fault.
This post has been edited by d3monc3lica: Feb 6, 2006 - 12:33 AM
post Feb 6, 2006 - 1:35 AM
team_omega
Joined Aug 14, '05
From St. Paul, MN(USA)
did you check your engine oil??? It might be that because same thing happened to my brother's 5th gen celica.
post Feb 9, 2006 - 1:56 PM
d3monc3lica
Joined Aug 19, '04
From Maine
nah i topped off my hydraulic fluid for the clutch with some break fluid and its been working fine ever since....
Lo-Fi Version Time is now: August 20th, 2026 - 7:50 PM
