> **UPDATED** NEED CUSTOM RIM DESIGNS, 1996 Land Rover Discovery SD
post Feb 7, 2006 - 10:01 PM
spunky393
Joined Apr 22, '04
From illinois
hopefully somebody on the site as one of these land rovers with rims. i'm having the hardest time finding the right rims for it
help?
This post has been edited by spunky393: Feb 8, 2006 - 5:33 PM
post Feb 7, 2006 - 11:23 PM
creis
Joined Jan 10, '04
From Shoreline, WA
Stock size for a 1996 Land Rover Discovery is 255/65-16
so upgrading to 17" would give you tires with a profile of 60, then 17" would give you 55 then 18"would be 50's i believe.
This post has been edited by creis: Feb 7, 2006 - 11:24 PM
post Feb 7, 2006 - 11:54 PM
spunky393
Joined Apr 22, '04
From illinois
no no no ... thanks for that little information though, i didnt' know that
i need to know what size the spacing is on the landrover, so i can get rims that will actually fit on it right.
post Feb 7, 2006 - 11:58 PM
boosted_K2
Joined Aug 30, '02
From Michigan
it appears you are looking for a +25mm offset with a 5X165 bolt pattern. where to get those? good luck! tire rack only has 1 set of wheels that would fit it: http://www.tirerack.com/servlet/CallJsp?ta...&filterSpecial=
No but I don't buy it
Cause I'm...
post Feb 8, 2006 - 5:33 PM
spunky393
Joined Apr 22, '04
From illinois
turns out that boost was pretty much right. i have to have them completly custom made. so, everybody, lets see them designs!!! 22 inch preferable design.
Lo-Fi Version Time is now: August 26th, 2026 - 9:50 PM
