Feb 10, 2006 - 2:12 AM
![]() Enthusiast ![]() ![]() Joined Jan 13, '06 Currently Offline Reputation: 0 (0%) |
when ever i start my car in the morning or a cold start the boost gauge needle shakes pretty hard :!: i can hear it and see it. at first it moves up and down like 2-3 inches of mercury (in-Hg) then as the car warms up a little it calms down and just dose it when i have throttle at like 60% and the needle is at like 5. so when I'm accelerating and try to keep my gauge at 5 it will shake very little but you can hear it and see it if you look hard.?
Feb 10, 2006 - 4:14 AM
what brand is it? what is your vac at idle? what engine is this on?
This post has been edited by lagos: Feb 10, 2006 - 4:14 AM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 10, 2006 - 4:17 AM
its a iEguus.
like 20. 7AFE |
Feb 10, 2006 - 4:25 AM
QUOTE its a iEguus. im going to take a wild guess and say tha gauge is the problem. ive never seen that brand before. its probably something really cheap and probably not working right? -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 10, 2006 - 5:59 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) |
from a guessing stand point i would agree, if you have something like an autozone around you rent a tool to measure vacum aside from ur boost gauge, let the motor idle (DO NOT BOOST) and see what type of readings you get, if they are low for the 7a its a possible boost leak, but the gauge itself may be the leak so first test I would do is bypass teh boost gauge line and reconnect the source to how it would be if the gauge did not exist. then retest your vacum (again DO NOT BOOST) with the tool.
-------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Feb 10, 2006 - 8:19 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
You can hear your boost gauge? Hahahaha...sorry man, but that just read too funny.
Feb 10, 2006 - 11:42 PM
QUOTE(celicast3sgte @ Feb 10, 2006 - 4:59 AM) [snapback]391691[/snapback] from a guessing stand point i would agree, if you have something like an autozone around you rent a tool to measure vacum aside from ur boost gauge, let the motor idle (DO NOT BOOST) and see what type of readings you get, if they are low for the 7a its a possible boost leak, but the gauge itself may be the leak so first test I would do is bypass teh boost gauge line and reconnect the source to how it would be if the gauge did not exist. then retest your vacum (again DO NOT BOOST) with the tool. i dont have boost...just got my turbo + manifold today..... dose autozone rent out things like that?....i dont know but i'ma redo my TEE ...it is kinda shady. |
Feb 11, 2006 - 9:09 PM
i got it....it was the tee..
the area to fit the tee is really small ..
Feb 11, 2006 - 11:10 PM
Never mind .
Feb 11, 2006 - 11:18 PM
its a crappy cheap gauge.... get autometer, at the very least.
Feb 12, 2006 - 12:10 AM
i'ma try another gauge.
| Lo-Fi Version | Time is now: June 26th, 2026 - 8:25 AM |
