> Suburu knock sensor, Ignition retarding
post Feb 15, 2006 - 3:41 PM
jiranz5
Joined Feb 12, '06
From Waimate, South Island, New Zealand
I apologize for this not being a 6g topic but am kinda stuck as to what to do so any productive info will be appreciated. Anyway, here's the story:
My dad owns a 1992 Suburu Legacy GT with something like 350,000kms on the clock. Recently the ignition has started being retarded and upon moving the knock sensor to a new location has reduced the problem. Another factor that reduced the problem was using a higher octane fuel. Does anyone know how to fix this problem or even bypass the knock sensor? Removing the knock sensor enirely doesn't work. Also he is running a twin WRX chipset system (however that works).
post Feb 15, 2006 - 3:45 PM
i dont know much about subaru, but that looks like the cause of your problems right there.
you do not want to remove the knock sensor. it is there to protect your motor. without it, the engine will detonate and fail.
post Feb 15, 2006 - 3:48 PM
SeanGTS
Joined Jul 27, '04
Instead of trying to band aid the problem, you need to find out why your experiencing spark knock, detonation, pre-ignition, whatever you want to call it. Possible causes of knock:
http://www.misterfixit.com/deton.htm
Google search engine knock, you'll get thousands of hits.
Most likely he may need to freshen up his ignition componets.
Lo-Fi Version Time is now: August 11th, 2026 - 2:59 PM
