Feb 17, 2006 - 12:15 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 31, '02 From Virginia Currently Offline Reputation: 4 (100%) |
Well, I got the front springs on which were pretty easy. Comments, tips, observations...
- Make sure you loosen the Top middle bolt SOME (in engine bay) before taking the suspension assembly out of car...this will make it easier to get the bolt off once it is out of the car...also, make sure you don't have the top cap facing you when you take off the middle bolt - it will come shooting out along with the bolt. I laid the assembly on the ground and pointed it away from me - You will be able to tell easily how the spring sits in there when putting the new one in - if you have a Haynes manual or equivalent, look at the torque specs before tightening all the bolts back on I am in the middle of doing the rear and it has been hell so far. I followed Manny's advice to the tee with the sway bar link bolt, but still stripped one of those allen heads...used a hand saw forever to get that damn link off and then went to Pep Boys and got a new one ($40). Other than that, the suspension bolts (hooked to suspension arms) would not budge despite my big ass torque wrench, so those got PB blasted and are soaking over night... To Be Continued, and can't wait to show yall pics when done...damn rusty old cars (wish all the bolts were as easy as the brake line bolts...that would be heaven) |
Feb 17, 2006 - 10:54 AM
QUOTE make sure you don't have the top cap facing you when you take off the middle bolt - it will come shooting out along with the bolt. I laid the assembly on the ground and pointed it away from me good tip, but you should have used a spring compressor. its a lot safer. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 17, 2006 - 11:07 AM
PB blaster does miracles!
good luck dude This post has been edited by playr158: Feb 17, 2006 - 11:09 AM |
Feb 17, 2006 - 11:31 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
I had the ghetto spring compressors where you have to twist it close and open... It was tough labor work....
Feb 17, 2006 - 1:57 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
i hate when problems occur...well i guess that's murphy's law.
gL! if ur in no. va i can help u out if u want. |
Feb 17, 2006 - 5:41 PM
Damn this sucks...I just got home after PB Blasting (last night) those two damn lower Rear Supension bolts on either side. I just got a 1/2" drive 18" breaker bar and 6 pt 3/4" socket and tried like hell to break those bolts loose to no avail. I was pulling like mad and am not THAT weak, but I don't want to pull the car off the jack stands either. The Fronts were much easier to get off (?).
Any suggestions? Air tools? Thanks. |
Feb 17, 2006 - 8:52 PM
lol are you turning both to the left?
Feb 17, 2006 - 9:05 PM
air tools rule!
Feb 17, 2006 - 10:45 PM
liquid wrench works...
so does remembering righty tighty / lefty loosey |
Feb 18, 2006 - 12:06 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 1, '03 From WV Currently Offline Reputation: 2 (100%) |
You should be using metric sockets on it. I'd be worried about stripping. I know there's a couple of sizes that match up about perfect, so 3/4 could be one. What is that, like 14mm? If you can get ahold of some air tools, that's your best bet. A good two piston air wrench will take it off or break it, either one in under 2 seconds. I love those things. Single piston will work just fine. I would try hitting it. Take a hammer and hit around it as hard as you can without tearing things up. This might knock some stuff loose. Just be careful. If worste comes to worste, use a grinder or hacksaw, then buy new parts.
Feb 18, 2006 - 12:28 PM
bad advice...i wouldn't hacksaw those bolts
and the bolts are 17mm or 19mm i forget defenitly NOT 14mm get two 1/2" drive socket wrenches and two 17mm or 19mm sockets (which ever it is) set them both on LEFT and grab a breaker bar.... get one wrench so that it spins around till its path gets blocked by the brake system which will hold it in place then on the other one use a breaker bar and give it a good push/pull you'll be fine This post has been edited by playr158: Feb 18, 2006 - 12:33 PM |
Feb 18, 2006 - 1:49 PM
QUOTE(playr158 @ Feb 18, 2006 - 12:28 PM) [snapback]395882[/snapback] bad advice...i wouldn't hacksaw those bolts and the bolts are 17mm or 19mm i forget defenitly NOT 14mm get two 1/2" drive socket wrenches and two 17mm or 19mm sockets (which ever it is) set them both on LEFT and grab a breaker bar.... get one wrench so that it spins around till its path gets blocked by the brake system which will hold it in place then on the other one use a breaker bar and give it a good push/pull you'll be fine I'm just saying if worste comes to worste. Like the situation comes up that he can't get them off with a wrench. Can't these be replaced? I'm not exactly sure what bolts are even being talked about here, I'm just going on general bolt knowledge. I still don't see how I gave bad advice. If you can't get a bolt off with a wrench, you don't really have much other option other than cutting it off. -------------------- Live Free, Be Happy
Feb 18, 2006 - 2:49 PM
well then you should read
he's refering to these i am pretty sure ![]() the 2 that are on the strut to knuckle......i HIIIIIIGHLY doubt there is a need to even attempt to cut as these are very hard grade metal...and pretty darn thick they should come off in any case with a good socket/breaker bar system or air gun... This post has been edited by playr158: Feb 18, 2006 - 2:50 PM |
Feb 18, 2006 - 8:29 PM
if u cant get it with a braker bar.... find a longer braker bar. you can use a 3/4ths. its one of the few standard sizes that is a perfect match to a 19mm size.
Feb 18, 2006 - 9:10 PM
Enthusiast ![]() Joined Oct 6, '05 Currently Offline Reputation: 0 (0%) |
what are the torque specs for the top bolt...?
-------------------- Willy //2o9// California |
Feb 19, 2006 - 3:10 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
Get creative! Use any kind of bar or even a huge lead pipe (like i use) to give you even more torque on your breaker bar.
Good luck. -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Feb 19, 2006 - 3:45 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
Who needs a breaker bar when you have a bigass ratchet and a 2 1/2ft long lead pipe?
Feb 19, 2006 - 9:21 AM
use vice grips -> & extension / breaker bar combo
Feb 19, 2006 - 5:21 PM
QUOTE(playr158 @ Feb 18, 2006 - 12:49 PM) [snapback]395938[/snapback] well then you should read he's refering to these i am pretty sure ![]() the 2 that are on the strut to knuckle......i HIIIIIIGHLY doubt there is a need to even attempt to cut as these are very hard grade metal...and pretty darn thick they should come off in any case with a good socket/breaker bar system or air gun... Thanks for the advice guys. These are the 2 bolts I'm talkin about (strut to knuckle). I've been away the past couple of days, but think I will try the lead pipe extension and then air tools. And YES, I am pulling to the LEFT This post has been edited by Celicav: Feb 19, 2006 - 5:23 PM |
Feb 19, 2006 - 5:39 PM
QUOTE(Willy2o9 @ Feb 18, 2006 - 9:10 PM) [snapback]396020[/snapback] what are the torque specs for the top bolt...? http://www.6gc.net/forums/index.php?showtopic=33982 |
| Lo-Fi Version | Time is now: August 27th, 2026 - 12:57 AM |
