Feb 17, 2006 - 12:15 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 31, '02 From Virginia Currently Offline Reputation: 4 (100%) |
Well, I got the front springs on which were pretty easy. Comments, tips, observations...
- Make sure you loosen the Top middle bolt SOME (in engine bay) before taking the suspension assembly out of car...this will make it easier to get the bolt off once it is out of the car...also, make sure you don't have the top cap facing you when you take off the middle bolt - it will come shooting out along with the bolt. I laid the assembly on the ground and pointed it away from me - You will be able to tell easily how the spring sits in there when putting the new one in - if you have a Haynes manual or equivalent, look at the torque specs before tightening all the bolts back on I am in the middle of doing the rear and it has been hell so far. I followed Manny's advice to the tee with the sway bar link bolt, but still stripped one of those allen heads...used a hand saw forever to get that damn link off and then went to Pep Boys and got a new one ($40). Other than that, the suspension bolts (hooked to suspension arms) would not budge despite my big ass torque wrench, so those got PB blasted and are soaking over night... To Be Continued, and can't wait to show yall pics when done...damn rusty old cars (wish all the bolts were as easy as the brake line bolts...that would be heaven) |
Celicav My Tein Experience Feb 17, 2006 - 12:15 AM
lagos QUOTE make sure you don't have the top cap fac... Feb 17, 2006 - 10:54 AM
playr158 PB blaster does miracles!
good luck dude Feb 17, 2006 - 11:07 AM
tomazws I had the ghetto spring compressors where you have... Feb 17, 2006 - 11:31 AM
purplegt4 i hate when problems occur...well i guess that... Feb 17, 2006 - 1:57 PM
Celicav Damn this sucks...I just got home after PB Blastin... Feb 17, 2006 - 5:41 PM
playr158 lol are you turning both to the left? Feb 17, 2006 - 8:52 PM
LewFX air tools rule! Feb 17, 2006 - 9:05 PM
purplegt4 liquid wrench works...
so does remembering righty... Feb 17, 2006 - 10:45 PM
Bigmeanbulldog55 You should be using metric sockets on it. I'd... Feb 18, 2006 - 12:06 PM
playr158 bad advice...i wouldn't hacksaw those bolts
a... Feb 18, 2006 - 12:28 PM
Bigmeanbulldog55 QUOTE(playr158 @ Feb 18, 2006 - 12:2... Feb 18, 2006 - 1:49 PM
playr158 well then you should read
he's refering to t... Feb 18, 2006 - 2:49 PM
Celicav QUOTE(playr158 @ Feb 18, 2006 - 12:4... Feb 19, 2006 - 5:21 PM
lagos if u cant get it with a braker bar.... find a long... Feb 18, 2006 - 8:29 PM
Willy2o9 what are the torque specs for the top bolt...? Feb 18, 2006 - 9:10 PM
Silver94CelicaOwner Get creative! Use any kind of bar or even a h... Feb 19, 2006 - 3:10 AM
95CelicaST Who needs a breaker bar when you have a bigass rat... Feb 19, 2006 - 3:45 AM
purplegt4 use vice grips -> & extension / breaker bar... Feb 19, 2006 - 9:21 AM
purplegt4 QUOTE(Willy2o9 @ Feb 18, 2006 - 9:10... Feb 19, 2006 - 5:39 PM
Celicav Well, I finally finished the installation and I st... Feb 20, 2006 - 9:08 PM
playr158 grease the top of your front springs really well t... Feb 20, 2006 - 9:52 PM
Celicav QUOTE(playr158 @ Feb 20, 2006 - 7:52... Feb 20, 2006 - 10:31 PM
LewFX the metal rings need greasing, but klunking from m... Feb 21, 2006 - 12:18 AM
playr158 the springs need to be able to twist with out bind... Feb 21, 2006 - 8:12 AM
Celicav QUOTE(playr158 @ Feb 21, 2006 - 6:12... Feb 22, 2006 - 11:23 PM
Celicav Well, you guys are great and so is this site. I d... Feb 24, 2006 - 12:41 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 27th, 2026 - 1:11 AM |
