Feb 25, 2006 - 1:34 AM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
Finally got round to fitting an inlet air temp sensor today. Bought a basic system from Oz which includes a probe and LCD monitor. Max / min alarms can be set with max / min recall.
Placement required a bit of work, but settled on just after the throttle. Involved removing the (inactive) cold start water injector and cutting off the nozzle. The housing was then drilled out to allow the probe to be pushed in - being held in place by an interference fit. A blob of silicone sealant around the base completed the job.. I have yet to decide where in the cabin to mount the monitor. With a short length of wire between the probe and display, I have to cut the wiring to insert a section to make life easier. Initial tests showed an average temp of between 35 - 40 deg C when the throttle is open and 45 deg C + when sitting in traffic. Interesting that as soon as you pull away and the pump is activated by the opening of the throttle, the temp drops almost instantly by at least 5 deg C. Still, despite typical warm ambient temps today, still have a bit of work to do to get those temps down BTW, while everything was apart, took the opportunity to mount a 0.4mm nozzle for the ERL water injection system I'll soon be running Gary -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Feb 25, 2006 - 2:32 AM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
Very nice, I was thing about adding in a Air temp sensor.
Are you sure that fitting wont pop off from boost ? Very nice -------------------- ![]() I will return one day. |
Feb 25, 2006 - 4:54 AM
QUOTE(defgeph @ Feb 25, 2006 - 2:32 AM) [snapback]399396[/snapback] Are you sure that fitting wont pop off from boost ? It's jammed in there so hard that it would probably take over 100psi before it popped out. And at that pressure, tehre would be other things to worry about instead Gary -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Feb 27, 2006 - 8:06 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
wow water injection!
keep up posted on how that goes, i'm very intrested in that system. |
| Lo-Fi Version | Time is now: August 30th, 2026 - 11:52 PM |
