Feb 26, 2006 - 6:58 PM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
With my new inlet temp sensor/monitor installed, decided to conduct a few tests.
First was to use a second probe placed between the turbo outlet and WAI. Ambient temp was 23 deg C Max temps seen during WOT were.. Turbo outlet - 110 deg C Inlet manifold - 41 deg C The above temps were recorded together during the same run. I have no doubt turbo outlet temps could have gone higher but I was somewhat restricted by the public roads I was using Average inlet temps were around 40 deg C with the lowest seen being 39 deg C. On idle and cruise, turbo outlet was averaging 65 deg C. Next, the probe was moved to the air filter intake pipe. Air filter is a A'PEXi cone type with no cold air box (yet). Lowest recorded temp was 33 deg C (while cruising with light throttle) with an average of 45 deg C. In stationary traffic, temp soared up to 60 deg C. Just goes to show the need for a cold air box Gives a good starting point for future comparisons. Plans include custom cold air box, larger capacity WAI pre-rad, pre-rad water sprayer, more heat shielding under the WAI itself and water injection. Gary -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Feb 27, 2006 - 11:55 PM
![]() Enthusiast ![]() ![]() Joined Nov 3, '05 From Chicago Suburbs Currently Offline Reputation: 1 (100%) |
Good stuff man!
Could you check temp at inlet manifold with ice + water for WAI ? Can you tell more about the plans for custom cold air box that you speak of? And your setup of water injection? I dont mean to bomb you with questions but thats some interesting stuff you are posting -------------------- QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback] i dont drive fast, i just fly low |
Feb 28, 2006 - 3:55 AM
Ice + water in the WAI is difficult to do due to the small fill hole on the top. Best option would be crushed ice I guess but not something I plan on trying as it isn't really useful in the real world of everyday driving. Only use would be immediately before a run on the drag strip.
I currently have a cone filter as mentioned and simply plan to design a carbon fibre enclosure to keep out the unwanted heat. A separate feed from under the car will ensure a good feed of ambient temp air. Water injection will be the tried and trusted ERL Aquamist system. I have used this to great effect on 3 previous cars. System will be set up on the dyno so no idea yet on what boost pressure it will be triggered at. Will be mostly to protect the engine when I throw 20+psi at it Gary -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Feb 28, 2006 - 10:07 AM
QUOTE Ice + water in the WAI is difficult to do due to the small fill hole on the top. Best option would be crushed ice I guess but not something I plan on trying as it isn't really useful in the real world of everyday driving. Only use would be immediately before a run on the drag strip. Please Gary! just for comparison purposes! Pleeease! And another thing... i do not want to give out my secret plans but could you source a CO2 tank 5-10 pound, run the the hose to water inlet and from water outlet at WAI run a hose to underneath and past the intake filter... and just record temps at throttle @ 13 psi with the CO2 unleashed... I am serious about this one, I could get the CO2 tank shipped to you, if you can't get one, but only if you promise to post the results QUOTE I currently have a cone filter as mentioned and simply plan to design a carbon fibre enclosure to keep out the unwanted heat. A separate feed from under the car will ensure a good feed of ambient temp air. You know you "HAVE TO" fill us in on design, dimensions, mounting and material pricing on this Could you build me one? I'll pay you! QUOTE Water injection will be the tried and trusted ERL Aquamist system. I have used this to great effect on 3 previous cars. System will be set up on the dyno so no idea yet on what boost pressure it will be triggered at. Will be mostly to protect the engine when I throw 20+psi at it Gary What boost levels you expect to be attainable with your set up with premium pump gas without any knock? -------------------- QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback] i dont drive fast, i just fly low |
Feb 28, 2006 - 10:34 AM
Enthusiast Joined Feb 27, '06 From Orlando, FL Currently Offline Reputation: 0 (0%) |
Just a tip for your intercooler sprayer... (I'm a new 6G Celica owner, but have an EvoVIII)
Not sure about the weather where you guys are, but in the winter to keep your sprayer lines from freezing just add half + half windshield washer fluid and water to your resevoir tank. |
Feb 28, 2006 - 2:58 PM
CilverSeliST205
If you want to experiment, then do it on your own car kitty Doesn't get cold enough here in AKL to worry about freezing Oh, and rather than relying on a simply 'push button' switch in the cabin to activate teh wtaer sprayer, will be using one of these... ![]() Will allow better control Gary This post has been edited by GT4WRC: Feb 28, 2006 - 3:01 PM -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Mar 1, 2006 - 12:17 AM
Trust me man i will experiment, just wanted to see if it would be worth it before I invest $$$ into WAI
Where did you buy that temp sensor from and how much $? Oh and with that h2o injection how many psi would you run on pump gas and still feel safe? -------------------- QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback] i dont drive fast, i just fly low |
Mar 1, 2006 - 1:13 AM
Temp gauge and probe -
http://www.jaycar.co.nz/productView.asp?ID...eMax=&SUBCATID= Boost levels will depend on how the Apexi Power FC is tuned. Once everything else is done, the we'll see how things go on the dyno. At this stage, it is pure guess work. Gary -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
| Lo-Fi Version | Time is now: June 23rd, 2026 - 6:08 AM |
