Mar 2, 2006 - 1:36 AM
Enthusiast ![]() ![]() ![]() Joined Feb 27, '04 From Illinois Currently Offline Reputation: 1 (100%) |
I need to know if an ST205 Wiring Harness would work with an ST185 motor. What parts would I need to make it work if there are slight modifications to make?
Thanks, Steve -------------------- ![]() |
Mar 2, 2006 - 2:26 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
I'm not sure if this is what you mean, but you can use an ST205 ECU, harness, injectors, map sensor, and coil on the ST185.
I have an ST205 ECU if you need one. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Mar 2, 2006 - 5:22 PM
So the wiring harness, ecu, injectors, map sensor and coil packs all have to be from the same generation motor? How much are you looking to get out of the ECU?
Mar 2, 2006 - 5:52 PM
Yes, that's correct. For the injectors, I think just the ST205 ones are specific. I'd like to get $300 shipped or best offer.
| Lo-Fi Version | Time is now: September 12th, 2026 - 2:21 AM |
