Mar 2, 2006 - 6:38 PM
Enthusiast ![]() Joined Dec 11, '05 From MN, Rochester Currently Offline Reputation: 1 (100%) |
Should I get a drop in air filter use a cold air intake on my 3SGTE motor?
Mar 2, 2006 - 8:12 PM
Generally theres no room for the stock airbox in the swap. I think you'll be quite alright with a short ram. Remember you have a hot turbo after the intake.
Mar 3, 2006 - 9:37 PM
What are some good short ram intakes then? I was looking at the HKS super power flow intake kit. Does anyone know if the HKS intake kit will fit the 3SGTE? if HKS does what is the part#?
Thanks for the help |
Mar 3, 2006 - 10:03 PM
Enthusiast ![]() ![]() ![]() Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
um,,, well i had no problem whatsoever with the stock air box (5th gen swap into 6th gen ST at200) but i took it off to replace it with a K&N FIPK kit. fits fine. the real question is who makes a decent replement for the stock rubber intake piping.
Mar 3, 2006 - 10:33 PM
I used a modified GT short ram piping w/ K&N filter.
Mar 4, 2006 - 1:31 AM
Ok other then the Air intake. Can anyone tell me more about the air to air Intercooler? How do I feed cold air to the intercool to cool the turbo? will the old hood work? or should I find a new hood with vents? Will water get into the air intake and intercooler if the hood has big vents to feed cool air to the turbo and intake?
Mar 4, 2006 - 1:08 PM
you need to ditch the TMIC and get a good FMIC
the top mount NEEDS a scoop to even function. and even then, theres a reason the alltrac owners call it a "interwarmer" lmao -------------------- Former Team 5SFTE pro member ;)
Mar 6, 2006 - 6:39 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 16, '04 From UK Currently Offline Reputation: 0 (0%) |
QUOTE(ToysRfast @ Mar 4, 2006 - 2:37 AM) [snapback]402414[/snapback] What are some good short ram intakes then? I was looking at the HKS super power flow intake kit. Does anyone know if the HKS intake kit will fit the 3SGTE? if HKS does what is the part#? Thanks for the help Yes, because I have one on my car. Don't know the part number though. -------------------- JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000 Needing another one 18000 miles later, bloody annoying. |
Mar 6, 2006 - 1:07 PM
^ I like his reasoning. Its on my car, therefore its good
Mar 16, 2006 - 6:10 PM
QUOTE(Supersprynt @ Mar 6, 2006 - 6:07 PM) [snapback]403378[/snapback] ^ I like his reasoning. Its on my car, therefore its good More, "it's on my car, therefore it certainly fits"..... Sounds louder. Not had a dyno, so no idea if it adds any performance. -------------------- JDM ST205
| Lo-Fi Version | Time is now: August 11th, 2026 - 7:30 PM |
