> PICS: of my custom struts, shorten struts
post Mar 3, 2006 - 12:47 PM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
AGX 4 way ajustable inserts....
Ground Control coilovers...
post Mar 3, 2006 - 12:51 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
nice.
how do they feel?
post Mar 4, 2006 - 7:45 AM
exactly where did you get them, and how much did you pay?
this is sticky material if we can get all the info for them!
post Mar 5, 2006 - 1:41 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Heh... I've toyed around with this idea after doing some AE86 struts... but basically Toyota uses very similar inserts for their macphearson struts. That said, you can use MR2 AGX shocks (most readily avail) and drop them in... but I believe the Celica strut casing is slightly longer, so a spacer will be needed, or you simply shorten the casing. What punch did was shorten the casing, cut off the perch, and welded on coilovers. Pretty standard for DIY suspension...
post Mar 5, 2006 - 10:35 AM
Punch
Joined Jan 29, '04
Thats pretty much it in a nut shell the front was cut& shorten but still needed spacers on the front but no spacer for the back & the insert or for a mr2.
It's been done befor: http://www.celicatech.com/forums/showthread.php?t=6031
This post has been edited by Punch: Mar 6, 2006 - 1:35 AM
post Mar 5, 2006 - 11:37 AM
tim86
Joined Oct 31, '03
From Orlando, Florida
how is the ride quality compared to your cut springs? I'm sure its better, but is it very bumpy, do you ever rub with this setup too?
post Mar 5, 2006 - 4:51 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
What do you use as spacers ?
Would these MR2 rear inserts would work for front and rear on our cars ?
I will return one day.
post Mar 6, 2006 - 1:34 AM
Punch
Joined Jan 29, '04
the pics are the front of the car...
post Mar 6, 2006 - 4:01 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
I realize those are pictures of the front. My questions are, what did you use as spacers ?
And, do the MR2 rear inserts work on the front and rear of our cars ?
Thanks
DEF
post Mar 6, 2006 - 12:08 PM
Punch
Joined Jan 29, '04
QUOTE(defgeph @ Mar 6, 2006 - 9:01 AM) [snapback]403254[/snapback]
Thanks
DEF
custom spacer made by a mich shop, yea the mr2 inserts fit....
post Mar 6, 2006 - 11:15 PM
How's the handling with the AGX shocks and Ground Controls? And what's your setup on the rear?
post Mar 7, 2006 - 2:37 AM
Punch
Joined Jan 29, '04
QUOTE(Coomer @ Mar 7, 2006 - 4:15 AM) [snapback]403702[/snapback]
same set up with no spacers in the rear...
post Mar 7, 2006 - 2:42 AM
Punch
Joined Jan 29, '04
QUOTE(presure2 @ Mar 4, 2006 - 12:45 PM) [snapback]402526[/snapback]
Order the insert from a Local fabercation shop called Wright Touch $100 each a insert+ & $350 ground control +$40 a spacer
Lo-Fi Version Time is now: August 28th, 2026 - 1:39 AM
