> 3sgte Swap Complete!!!
post Mar 3, 2006 - 6:19 PM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
well today was the best day in a LOOONG time (about 2 years). i got a call from my guy at the shop and he said the swap was done. OH JOY.
i picked it up and went driving around for a few hours...not really beating on it too bad, but i was giving it some gas a few times. wow this thing is awesome. its tough to find the gears sometimes (i need to re-do my mr2 tranny shifter conversion). and i need to grind down the passenger side engine mount cuz its resting on the timing gear cover.
so now here's the first inevitable problem...i was on my way home on a country road and stepped on it a little, and it died. at first i thought it just stalled so i tried to start it back up, and it died again. i pull over and started it and it idled ok, but if i even touched the gas a little, it died.
i called the shop and he said it sounded like my fuel pump went out. does that sound right to you guys? i was expecting this to happen cuz i was using my 7afe fuel pump (i know, BAD idea). so now's my chance to get a new one.
- gtfc115   3sgte Swap Complete!!!   Mar 3, 2006 - 6:19 PM
- - nik   QUOTE(gtfc115 @ Mar 3, 2006 - 5:19 P...   Mar 3, 2006 - 6:30 PM
- - gtfc115   QUOTE(nik @ Mar 3, 2006 - 11:30 PM) ...   Mar 3, 2006 - 6:33 PM
- - Supersprynt   If the car started up and idled fine I dont think ...   Mar 3, 2006 - 6:35 PM
- - gtfc115   well it was my fault...he didnt know anything abou...   Mar 3, 2006 - 6:37 PM
- - gtfc115   oh, and i should post this in the other thread. b...   Mar 3, 2006 - 6:47 PM
- - lagos   you probably have a vac leak causing you car to st...   Mar 3, 2006 - 6:54 PM
|- - presure2   QUOTE(lagos @ Mar 3, 2006 - 6:54 PM)...   Mar 4, 2006 - 8:25 AM
- - j0e_p3t   hold up... it took 2 years to do the swap?   Mar 3, 2006 - 6:58 PM
- - gtfc115   QUOTE(j0e_p3t @ Mar 3, 2006 - 11:58 ...   Mar 3, 2006 - 10:57 PM
|- - madmods   QUOTE(gtfc115 @ Mar 4, 2006 - 3:57 A...   Mar 4, 2006 - 12:34 AM
- - StreetRacing10PSI   check your boost guage. if you are running less th...   Mar 3, 2006 - 11:07 PM
- - snapshotgt   ...does not sound like your swap is complete Good...   Mar 3, 2006 - 11:30 PM
- - gtfc115   QUOTE(StreetRacing10PSI @ Mar 4, 2006 - ...   Mar 3, 2006 - 11:30 PM
- - CelicaZR   Congrats on your swap Wow... 2 years in a very l...   Mar 3, 2006 - 11:48 PM
- - lagos   QUOTE(gtfc115 @ Mar 3, 2006 - 11:30 ...   Mar 4, 2006 - 12:16 AM
- - Supersprynt   haha, every single post.   Mar 4, 2006 - 12:31 AM
- - lagos   QUOTE(Supersprynt @ Mar 4, 2006 - 12...   Mar 4, 2006 - 12:36 AM
|- - madmods   QUOTE(lagos @ Mar 4, 2006 - 5:36 AM)...   Mar 4, 2006 - 12:42 AM
- - lagos   just read the thread below this one.   Mar 4, 2006 - 12:47 AM
|- - madmods   QUOTE(lagos @ Mar 4, 2006 - 5:47 AM)...   Mar 4, 2006 - 12:55 AM
- - gtfc115   ok well i got the car back...turns out my IC pipin...   Mar 4, 2006 - 12:52 PM
- - lilsteeg   did you look at the how to on celicatech, it has a...   Mar 4, 2006 - 12:57 PM
- - lagos   get the walbro if you want cheap or an oem supra ...   Mar 4, 2006 - 3:54 PM
- - gtfc115   just got a walbro supra pump 255lph, blah blah...c...   Mar 4, 2006 - 7:36 PM
- - defgeph   The fuel pump install is very easy. Use plenty of ...   Mar 4, 2006 - 8:34 PM
- - lagos   QUOTEThe fuel pump install is very easy. Use plent...   Mar 4, 2006 - 10:08 PM
- - gtfc115   thanks def. i'll have to post a pic of where m...   Mar 5, 2006 - 11:12 AM
- - presure2   make sure theyre useing the GT BRACKET, and not ju...   Mar 5, 2006 - 11:46 AM
- - lagos   QUOTE(gtfc115 @ Mar 5, 2006 - 11:12 ...   Mar 5, 2006 - 2:30 PM
- - defgeph   Very true. Installing that 6th gen GT passenger si...   Mar 5, 2006 - 2:55 PM
- - gtfc115   i havent even thought of taking on the highway...i...   Mar 5, 2006 - 3:52 PM
- - Silver94CelicaOwner   Its time to get the hands dirty. From the sounds ...   Mar 6, 2006 - 3:00 PM
- - gtfc115   Awesome man Thanks! im not driving it untill ...   Mar 6, 2006 - 11:11 PM
- - gtfc115   so, like i mentioned before, my battery has been d...   Mar 7, 2006 - 11:21 PM
- - gtfc115   and it looks like the tranny has stopped leaking.....   Mar 7, 2006 - 11:26 PM
- - lagos   there is a caped off vac port on the back of the i...   Mar 7, 2006 - 11:32 PM
Lo-Fi Version Time is now: August 4th, 2026 - 10:39 AM
