Mar 4, 2006 - 12:42 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 16, '06 From Lima, ohio Currently Offline Reputation: 0 (0%) |
ok some of may have heard about my spark plug shooting outa my head, well i decided, since there are shavings in the motor now, to go ahead and this summer swap in, ok get ready, a silvertop 20v,
a few questions, tweak- how much wiring will need to be done on this swap, and will this engine bolt right up to my stock st tranny, and what else will i need besides engine, ecu, exhaust, and wiring, thanks and ill keep you guys posted, i will start the disassembly of the old engine hopefully next week. |
Mar 4, 2006 - 1:21 PM
http://cgi.ebay.com/ebaymotors/4age-ECU-19...sspagenameZWDVW
will this ecu work on the 20v |
Mar 4, 2006 - 4:04 PM
bump
Mar 4, 2006 - 4:12 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
QUOTE(lilsteeg @ Mar 4, 2006 - 1:21 PM) [snapback]402591[/snapback] no |
Mar 7, 2006 - 1:38 PM
![]() Enthusiast ![]() ![]() ![]() Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) |
Read the stickies and know what ur getting into. Buy a front clip if you decide to go ahead and do the swap. Be very prepared to have your car out of commission for weeks if not more.
Dont try and take a swap lightly they are a lot of work and everyone is a bit different. -FAQ -------------------- AIM : FAQdaWorld
Mar 7, 2006 - 3:10 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
All the information you need has already been covered.
You can use your stock Trans, and stock motor mounts. That is about all you can use though. You will have to get a Throttle cable from a trecel to be able to reach, as it is on the other side of the engine. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Mar 7, 2006 - 9:43 PM
QUOTE(FAQdaWorld @ Mar 7, 2006 - 1:38 PM) [snapback]403962[/snapback] Read the stickies and know what ur getting into. Buy a front clip if you decide to go ahead and do the swap. Be very prepared to have your car out of commission for weeks if not more. Dont try and take a swap lightly they are a lot of work and everyone is a bit different. -FAQ well the car is gonna be outa commission for a while |
Mar 8, 2006 - 4:21 PM
ok i got the engine, now i need to find ecu, wire harness, afm, ignitor coil, and tercel throttle cable, now the question, what year tercel and about how much would it cost from a dealership
Mar 9, 2006 - 4:20 AM
Once again you should have read the stickies and listened to the advice that was offered to you in this thread even. Buying the engine by itself was a mistake, sourcing those parts could be a giant pita and will probably cost the same if not more than simply buying a front end clip.
Swaps are not simply to just 'hop' into which is obviously what you are doing right now... -FAQ -------------------- AIM : FAQdaWorld
Mar 9, 2006 - 9:46 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
QUOTE(lilsteeg @ Mar 4, 2006 - 12:42 PM) [snapback]402563[/snapback] tweak- how much wiring will need to be done on this swap, and will this engine bolt right up to my stock st tranny, and what else will i need besides engine, ecu, exhaust, and wiring, thanks and ill keep you guys posted, i will start the disassembly of the old engine hopefully next week. 1.) Yes lots of wiring, do not attempt if you do not know about the basic wires 2.) yes it will bolt up 3.) Yes u need a new exhaust 4.) U need an AFM, External Coil, Igniter, 5.) After You have all that everything will bolt up, minus the part where you need to go and buy some hoses to work with the Brake booster vaccum, and P/S? |
Mar 9, 2006 - 3:19 PM
QUOTE(FAQdaWorld @ Mar 9, 2006 - 4:20 AM) [snapback]405015[/snapback] Once again you should have read the stickies and listened to the advice that was offered to you in this thread even. Buying the engine by itself was a mistake, sourcing those parts could be a giant pita and will probably cost the same if not more than simply buying a front end clip. Swaps are not simply to just 'hop' into which is obviously what you are doing right now... -FAQ well no, i got the engine for $350, also i couldnt find any clips, and i am not waiting until i find one to do the swap |
Mar 9, 2006 - 3:34 PM
got the ecu now
Mar 9, 2006 - 3:39 PM
http://cgi.ebay.com/ebaymotors/MR2-4AGE-Ai...044856538QQrdZ1
im not sure and dont think it will, but will this afm work |
| Lo-Fi Version | Time is now: August 27th, 2026 - 1:58 AM |
